Options
URL: http://forums.avidyne.com/forum_posts.asp?TID=2199
Printed Date: 22 Feb 2025 at 3:34pm
Topic: Options
Subject: Options
Date Posted: 14 May 2021 at 8:29pm
I got a replacement 540 recently and notice there is a setting on the Options page of the Setup tab called "ADS-B Forwarding."  It can be set to either on or off.  Can someone tell me what it is for?  It is not on my 550.
Date Posted: 15 May 2021 at 9:55pm
It's not in the Pilot's Guide yet, but it will be for 10.3, where the title has been changed to "ADS-B Over WiFi".  When that setting is "On", the IFD will forward data received from a wired ADS-B In source over the WiFi interface.  Most Electronic Flight Bag (EFB) applications will use this data to display weather and/or traffic.  Some EFBs can be configured to get ADS-B data over other interfaces (e.g. Bluetooth).  In those cases, this setting should be “Off”.
Date Posted: 15 May 2021 at 10:25pm
Thank you.  I guess that explains why I wasn’t seeing traffic on FF or the IFD 100 until I turned this on. I don’t recall seeing this on the IFD I sent in for exchange but that one was on 10.2.4.1 also. Is it possible my unit didn’t have that or did I just miss seeing it all that tome?  :( Since my 550 has XM weather,  I guess that explains why that option isn’t there.
Date Posted: 15 May 2021 at 11:22pm
It was in 10.2.4.1 so maybe you just didn't notice it?  It only appears if you have the IFD configured for an ADS-B weather source.
