Lost SVS Tab after 10.2.6.1 update
URL: http://forums.avidyne.com/forum_posts.asp?TID=2184
Printed Date: 13 Jul 2025 at 8:48am
Topic: Lost SVS Tab after 10.2.6.1 update
Posted By: dwbarnett
Subject: Lost SVS Tab after 10.2.6.1 update
Date Posted: 18 Apr 2021 at 9:17pm
Title say it all. After updating to the latest for my IFD440, I no longer have my SVS tab on the MAP page.
Is there something else I need to do? Avionics shop did update. Shop already closed when I noticed it missing.
I know there used to be a small file, is it automatic with the latest update?
Date Posted: 19 Apr 2021 at 9:30am
Somehow your IFD lost the corresponding paid option.  You'll have to get with tech support (or have your shop do it) to get the option restored.
Posted By: pburger
Date Posted: 21 Apr 2021 at 2:23pm
Oh man.  I need to double-check that!  We did my update Saturday.
Posted By: pburger
Date Posted: 26 Apr 2021 at 10:49pm
Following up.....
     My SVS tab is still there!!
Date Posted: 28 Apr 2021 at 9:40pm
Got it back. Shop just had to redo the file that activates SVS. The update screwed it up for some reason.
Also, screwed up my Stratus setup. Worked fine till updat, now can't connect on Stratus network. Works fine on LIO_WIFI
Argghh always something.
Posted By: AndyMeyer
Date Posted: 29 Apr 2021 at 9:48pm
Is there a way to turn off the SVS tab on the 540? I hate accidentally ending up on a page that I don't see helping me.
Thanks!
Andy
Date Posted: 30 Apr 2021 at 9:15am
Thanks!
Andy
Yes, you can call tech support and have them send you a DSF to remove the F500 option.  If you do that, however, you'll also lose FLTA alerts.  I wouldn't recommend it.
Posted By: Bonnell65
Date Posted: 04 Jul 2021 at 6:27pm
Avisteve
Have 440 running 10.2.3
About a year ago, lost SVS tab unexpectedly after it was there for a year. Thought it was related to database update. Evidently not. Updated databases. Getting LPV approaches, so I am assuming SBAS is good. BUT, no SVS…and…Trio AP needs GPSV for vertical on approaches.  Not getting it. Seems this is related to SVS dropping. Help!  Thanks!
Date Posted: 04 Jul 2021 at 6:34pm
Date Posted: 05 Jul 2021 at 9:09am
How did you manage to get the SVS option on and the F500 option off?  SVS does nothing on a 440.  F500 will enable the SVS tab on the Map page.  You'll need to call tech support and have them send you a DSF to reset your options.
Date Posted: 05 Jul 2021 at 11:40am
Thanks Steve!  And I have NO idea!
Posted By: saratogahp
Date Posted: 27 Nov 2021 at 8:41pm
Any updates from adopters of the 10.2.6.1 update?   I read only one user with an issue.  Any resolution or suggestions?  My A&P happy to sign behind, showing him the steps meticulously done, and settings before and after identical.  Ez enough.....in theory.  Unsure how stable this one was.
