Frequency tuning
URL: http://forums.avidyne.com/forum_posts.asp?TID=1915
Printed Date: 19 Apr 2025 at 11:23am
Topic: Frequency tuning
Posted By: PA23
Subject: Frequency tuning
Date Posted: 24 Dec 2019 at 10:39am
When I go to dial in a frequency the IFD440 will pop up a menu offering me potential frequencies.
Can I either disable this feature or have the menu auto-hide after a few seconds?
Jeff
Date Posted: 24 Dec 2019 at 1:02pm
Jeff,  I have the 540 but I believe it behaves the same.  Are you dialing in your frequency with the knobs on the left to change freq or are you hitting the freq button. Hitting that button does pull up  a list of suggested frequencies.  If you want to avoid the menu and just dial in the new freq, either use the wireless keypad (if you have one) or enter the frequency with the knobs or touch screen by touching the frequency box
Posted By: PA23
Date Posted: 24 Dec 2019 at 1:46pm
I'm turning the knob, basically ATC gives me a new frequency and I'm tuning it in at the same time.  as soon as I start twisting the bottom left knob the frequency suggestion menu comes up and it never self clears.
Date Posted: 24 Dec 2019 at 3:37pm
Understood.  I don't see that behavior on the 540
Date Posted: 24 Dec 2019 at 3:43pm
There's no way to disable the feature or have it time out.  You can manually dismiss it using various methods, including pressing the CLR key. It sure seems like it should dismiss when you swap in a new frequency.  I'll have to check with the radio guys to see why the UI was designed that way.  If nothing else, I would think we could add a timeout as you suggested.
Posted By: PA23
Date Posted: 26 Dec 2019 at 8:46am
Other issue, I don't know why a programmer thought that white lettering on a gray background is an easy combination to read, a little more contrast would be desirable!
Jeff
Posted By: Aerochip
Date Posted: 26 Dec 2019 at 5:28pm
On one of the Feature Request emails here or on FB, I made the suggestion that this should clear itself when you hit the Swap button.  This is for sure one of my bigger complaints on the 440.
