Keyboard lag???
URL: http://forums.avidyne.com/forum_posts.asp?TID=1890
Printed Date: 18 Jun 2025 at 11:25pm
Topic: Keyboard lag???
Posted By: PA23
Subject: Keyboard lag???
Date Posted: 11 Nov 2019 at 5:53pm
I am new to the IFD440 and just picked up the keyboard, and while the plane was down for maintenance I had the IFD440 sitting on my bench at home learning my way around it.  When I went to use the keyboard, I had no problem pairing it to the GPS but it was very sluggish, I press a key and many seconds later the GPS processed the button press.
I would have hoped the processing from the keyboard would be much faster.
Jeff
Date Posted: 11 Nov 2019 at 6:35pm
If it is in the range of 10sec, it is a faulty keyboard. Avi will likely replace it for you.
Normal lag is about 2 sec for the first keystroke, then it is pretty much instant. If you leave it sitting for a while, there is that initial 2 sec lag again.
