Compatibility with IFD 440
URL: http://forums.avidyne.com/forum_posts.asp?TID=1849
Printed Date: 24 Aug 2025 at 10:26pm
Topic: Compatibility with IFD 440
Posted By: nsayler
Subject: Compatibility with IFD 440
Date Posted: 10 Sep 2019 at 4:21pm
I'm considering upgrading the Garmin 430W in a 1961 Beech TravelAir.  Will the plug and play IFD 440 be compatible with a S-Tec 30 autopilot, Garmin GTX 345, Foreflight and Avidyne IFD100 on an Ipad.  I will have a NAV subscription thru Jeppesen.  Items to consider, concerns, incompatibility?  Appreciate all the support possible as mistakes would be costly.
Posted By: comancheguy
Date Posted: 10 Sep 2019 at 5:13pm
I have two IFD-540s wired to an Stec 50 and a GTX-345.  I use foreflight and the IFD1000.  It all works together.  Although, you may have a few issues.  If your shop is an Avidyne dealer, they'll figure it all out.
The "install" is, literally, side the 430W out and the 440 in.   My 530W -> 540 install was, in fact, that easy.
However, everything must be wired "just so" for EVERYTHING to work.   But, it should be fairly trivial (software upgrades, configs, and maybe a wire or two) for your shop.    I had a few issues when the 345 went in, but nothing too bad.
Ken
Date Posted: 10 Sep 2019 at 5:54pm
I have an IFD540 installed with an S-Tec 30 plus GPSS and it works great. It also works fine with FF and IFD100. With FF I just do flight plan transfers (both ways work, but I do mostly IFD to FF). Don't have a GTX 345 so can't comment there.
