New IFD simulator app & 10.2.3.x firmware update
URL: http://forums.avidyne.com/forum_posts.asp?TID=1668
Printed Date: 24 Apr 2024 at 9:08pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: New IFD simulator app & 10.2.3.x firmware update
Subject: New IFD simulator app & 10.2.3.x firmware update
Date Posted: 08 Jan 2019 at 9:37pm
OK, so there are videos about the new simulator update ...
https://youtu.be/pqiGUkF6hUk" rel="nofollow - https://youtu.be/pqiGUkF6hUk
But, not available in the app store yet.
In this video you can clearly see 10.2.3 in one of the screens. (at the 4m10s mark)
I am guessing that we won't see this until they pull trigger on this major update, but it must be very, very close now!
Posted By: AZ Flyer
Date Posted: 09 Jan 2019 at 3:26am
Different IFD 54x and 44x models are also shown starting at 4:06. No 540 or 440. Plus additional 5xx and 4xx models are shown.
Date Posted: 09 Jan 2019 at 7:22am
I don't think any of the listed models are new-- take a look at the bottom of the page at https://avidyne.com/products/ifd/index.html. The 410, 510, and 545 are GPS units only, with no VHF NAV/COM radio capability.
Posted By: compasst
Date Posted: 09 Jan 2019 at 7:56am
AviSteve recently posted this in the thread 540 vs 440 - HenryM wrote:
The IFD-100 and ForeFlight interfere with each other if both are active.... |
By the way, that exact issue is being worked as we speak. We plan to have it fixed for the next release of IFD100 (corresponding to IFD release 10.2.3.1). | |
Posted By: ttvetdoc
Date Posted: 09 Jan 2019 at 3:35pm
It looks like the video has been pulled unfortunately.
------------- SR22 - KEQY
Date Posted: 09 Jan 2019 at 4:09pm
Looks like someone goofed on the release. Well, it was tittler.
Date Posted: 09 Jan 2019 at 4:12pm
There is also this one ...
https://youtu.be/3ZrqscD2cmM" rel="nofollow - https://youtu.be/3ZrqscD2cmM
But, it doesn't show much.
Posted By: ttvetdoc
Date Posted: 09 Jan 2019 at 4:16pm
Looks like that original video may have been reposted by Avidyne. Here's the link
https://www.youtube.com/watch?v=Y5pQ4rxddDM
Posted By: CubedRoot
Date Posted: 09 Jan 2019 at 7:56pm
Lots of great new additions to the app! Now I am constantly refreshing my iPads app store to see when the update is available. LOL.
Posted By: D-EACY
Date Posted: 10 Jan 2019 at 1:59pm
Can anybody here tell me HOW to connect the IFD Trainer on my iPad Pro with IFD100 on my iPad mini 4? They are both on the same network but i cannot find out how to connect them!
------------- 2006 SR22-G2 DFC90 IFD440
Date Posted: 10 Jan 2019 at 6:34pm
It works exactly the same as if the IFD Trainer were a real panel IFD. That is, you need to check that the IFD Trainer is configured for wifi as if it were the real thing. Both IFD Trainer and IFD100 need to be at the same (i.e. latest) release and database levels. Have you gone through the setup process in the manual?
I just replicated your config (ipad air2 running IFD Trainer, ipad mini 4 running IFD100) and it works flawlessly.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 4:09am
Only that it doesn't work :-)
I have the Trainer on my iPad Pro and the IFD100 on my iPad mini. Both have the latest iOS (12.1.1.). Databases are the same, downloaded from my Jeppesen account. I even made a "Ping" test, the iPads can communicate ok.
Still no data transfer.
I cannot find a "setup process" in the manual. There's none, not in the IFD manual, not in the IFD100 manual.
Date Posted: 11 Jan 2019 at 6:50am
The setup information is in the IFD100 manual starting under "Initial Configuration" on page 6.
I'm running 12.0.1 iOS, but that would be the last thing I would expect to be the problem and Avidyne would need to answer if they both work on 12.0.1 but not on 12.1.1 iOS. Let's do some troubleshooting:
What app versions do you have? This can be seen on the ipad's under Settings/General/iPad Storage/ and then scrolling down and clicking on the app. For the IFD100 this should be 10.2.5 and for the IFD Trainer this should be 10.2.2.
What settings do you have for the IFD Trainer (Aircraft Type, Device Type)? What settings do you have for the iFD100 (IFD Type, IFD Chassis ID#, iPad ID#)?
Does the IFD Trainer present the Allow button for wifi & BT when you start it up? Once it's running, are the BT and wifi icons next to GPS at upper right corner green? This takes a minute or so to happen.
Is the wifi icon on the IFD100 also green? If you start the IFD100 first and then the IFD Trainer, the wifi icon should be flashing green with a grey barred circle (like "do not" on road signs) which should turn green as soon as the IFD Trainer wifi icon turns green. At the same time, the red X on the freq boxes should be replaced by the IFD Trainer primary and standby freq.
What software version is showing on the two devices? Both should have s/w 10.2.1.0. The Sys ID on the IFD Trainer should be the same as on the IFD100 (see above and on both devices AUX/SYS/Software Status LSK).
Let me know if all that checks out, or where you see different behaviour.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 6:55am
Thank you for this, will test all that this afternoon when i have time!
One thing: I do NOT have a WIFI symbol in the IFD100. And other than in the IFD and IFD trainer there is no "network" (or bluetooth) setting under AUX/setup.
And I am sure I have the latest versions, because there are no updates available for either app.
Date Posted: 11 Jan 2019 at 6:59am
Check the app versions anyway, just in case. I'm trying to make sure you have the same setup as I do, because mine works. Do you mean that there is no wifi symbol at all next to GPS at the upper right corner on the IFD100? You should always have the symbol, even if wifi is not working. As long that there is no connection to the IFD (Trainer or in-panel), then that wifi symbol will have the barred and greyed out circle and should flash. This is the indication that there is no connection.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 7:01am
Confirm - NO WIFi symbol next to GPS. In the airplane i simply connected it in the WIFI settings (once) and it works, same app on same iPad mini 4!
And, yes, I do have the versions you mentioned. Just checked!
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 7:05am
I also do have the WIFI symbol in the Trainer, it also turns to GREEN after a while, and confirm for the "ALLOW" screen on the trainer. All fine ...
Deleted and re-installed IFD100: no WIFI symbol.
Looks like the databases stayed on the iPad when I deleted the app ... no new downloaded necessary.
Date Posted: 11 Jan 2019 at 7:07am
I assume you mean no wifi symbol on the IFD100? If there is no wifi symbol, then the IFD100 is not connected to the wifi network at all.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 7:09am
No WIFI symbol on the IFD100 ... but full strength WIFI symbol on the iPad itself.
Is there a WIFI setting somewhere in the IFD100? If so then I cannot find it.
Date Posted: 11 Jan 2019 at 7:11am
From your signature, I see that you have an IFD440, so I assume that is what you have set for device type on the IFD Trainer and IFD Type on the IFD100? I changed my IFD100/Trainer to both IFD440 (I have IFD540), and it still worked fine.
Date Posted: 11 Jan 2019 at 7:13am
And you confirm the IFD100 app version is 10.2.5? And wifi network on both ipads is the same?
Posted By: D-EACY
Yes, set correctly!
IS there a WIFI setting in the IFD100 app?
Have to run, back in one hour ... if you have an idea?
(I also develop apps, so basic iOS knowledge exists, in case you wonder :-))
Date Posted: 11 Jan 2019 at 7:18am
There is no wifi setting on the IFD100. It relies on whatever wifi the iOS is using. It is really critical though that the Chassis/Sys ID # is 1. You can't set it on the IFD Trainer, it is always 1. You can check this under AUX/SYS/Software Status on both apps.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 8:39am
It's crazy .... SYS ID is set to 1 on both devices. I even re-installed the IFD100 app, but NO WIFI symbol in the IFD100 app!
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 8:52am
What's odd: On the screenshots in the IFD100 manual I cannot see a WIFI symbol in the IFD100.
Could you send me a screenshot?
I have now tried everything ... no luck. No WIFI symbol, no sync!
Date Posted: 11 Jan 2019 at 9:23am
Ok, here is what the IFD100 shows on my ipad mini when I start the IFD100 without any IFD Trainer active:
And here is a shot of what appears once I start the IFD Trainer on the other ipad (air2). Note that it takes a minute or so once the ALLOW button is pressed until first the BT icon appears and then later the wifi icon. As soon as the wifi icon appears on the IFD Trainer (ie within seconds), the wifi icon also appears on the IFD100, along with the Options fields and frequencies populated. Note that the Options field is not the same as the IFD Trainer. The IFD100 doesn't have ENET/IO or BT.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 9:26am
All that looks the same ... except the missing WIFI symbol. I borrowed my daughter's iPad now and will try again ...
Update: Can't do that either, don't have her password :-)
Date Posted: 11 Jan 2019 at 9:27am
If I turn off the IFD Trainer, the wifi symbol on the IFD100 turns white with the "do not" barred circle and then starts to blink blue and/or green, indicating I guess that it is still looking for the IFD Trainer.
If you have no wifi icon at all, then it would seem to indicate that the IFD100 has never seen the IFD Trainer on the network.
Date Posted: 11 Jan 2019 at 9:35am
I assume since you have an IFD440 that you are using the IFD Trainer as an IFD440, and your IFD Trainer looks like this:
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 9:40am
Exactly. But they are both on the same network and i even pinged one iPad from the other ... and in the settings of my Fritzbox I can see that they are both in the active list and that they are allowerd to communicate. Yes, looks exactly like yours.
Date Posted: 11 Jan 2019 at 9:42am
I'm sitting at home with both ipad's side-by-side, next to my Fritzbox! Strange.
Date Posted: 11 Jan 2019 at 9:45am
And your IFD100 has big red X's in the four freq boxes?
Posted By: D-EACY
Me too! I even managed to guess my daughter's password ... but same reulst on her iPad. NO WIFI symbol ...
The strange thing is that it works perfectly in the airplane. But since the weather is so bad I'd like to practice a bit :-)
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 9:46am
Yep, red crosses over the frequencies, no connection
Try turning the wifi off-on. Leave the IFD100 running.
Date Posted: 11 Jan 2019 at 9:50am
And your IFD100 settings look like this?
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 9:51am
Yes!
Date Posted: 11 Jan 2019 at 9:57am
I'm out of ideas, especially if the IFD100 works fine with the panel-mount in the aircraft. That is a different wifi network, so the problem must lie there somewhere unless there is a mis-match between the app versions or Jepp databases between the IFD100 and the IFD Trainer. You've confirmed the IFD100 and IFD Trainer app versions are the same as mine, so that is ruled out as a problem.
Maybe someone else on the forum has an idea.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 10:00am
Thank you very much for your help! I really double and tripe checked everything
- latest version - same database
- same iOS - same WIFO network. - #1 setting correct - IFD440 selected in settings
... but no connection and no WIFI symbol on IFD100
Have a nice weekend! Thanks again!
Date Posted: 11 Jan 2019 at 10:02am
The only other thought is to perhaps reverse the ipad's that you're using for the IFD Trainer and IFD100, to see if the problem is ipad related.
Date Posted: 11 Jan 2019 at 10:05am
And just to repeat (no offence intended) IFD100 app version is 10.2.5 and IFD Trainer app version is 10.2.2.
I've seen another thread that a new IFD100 app version is "imminent" (i.e. Youtube video posted), so perhaps that will resolve your problem.
Posted By: D-EACY
Date Posted: 11 Jan 2019 at 10:07am
Yes, I double checked that too ... correct version on both devices!
Thank you very much!
Yes, looking fwd to the new version ... maybe that will solve it!
Date Posted: 12 Jan 2019 at 9:39am
I just updated both ipads to 12.1.1 and my setup still works, so it's not related to iOS release. One thought that just came to mind is if there is something in your fritzbox wifi setup. Just being able to ping from one device to another might not be enough if you have some sort of protection on the wifi such as specific tcp ports or packet types being blocked, etc. A ping just sends a udp packet. That would also explain why the IFD100 talks to the in-panel unit fine as it is a different wifi network without any hub/router.
Posted By: D-EACY
Date Posted: 12 Jan 2019 at 11:51am
Thanks a lot!
I had the same idea, so i opened the FritzBox menu. It says that the two iPads are "allowed to communicate". Shouldn't that be enough?
In the meantime I have tried everything possible! Deleted and re-installed the app, re-installed my databases, tried the DEMO-database. ... nothing :-)
Date Posted: 03 Mar 2019 at 11:04pm
I have the same problem as D-EACY. My IFD100 will not connect with the Trainer app running on another iPaD.
I am running the latest App Store versions of both the Trainer (10.2.1.0) and the IFD100 (10.2.2.0.A) that are currently available. Both are loaded with the latest Jepp downloads. Both iPads are running iOS 12.1.4.
The IFD100 on my iPad Mini never shows a wifi symbol, and never connects to my iPad Pro which does show a wifi symbol when running the Trainer.
Both iPads are connected to my home network of course.
Why doesn't this work?
Date Posted: 04 Mar 2019 at 9:48am
It should work, we run those two versions together all the time. It's possible that it could be running out of memory on the iPad mini. Make sure all other apps are closed on that device (especially given that you're running iOS 12). There's also an off chance that it could be your local network firewall blocking UDP traffic.
Posted By: donemory
Date Posted: 04 Mar 2019 at 2:17pm
FYI...I run both Simulator IFD540 & IFD100 with latest software version on 2 different iPad mini, (Mini 2 & Mini 4) on home network and all works well! Great to have this training system available.
------------- Don
Date Posted: 05 Mar 2019 at 12:46am
AviSteve wrote:
It should work, we run those two versions together all the time. It's possible that it could be running out of memory on the iPad mini. Make sure all other apps are closed on that device (especially given that you're running iOS 12). There's also an off chance that it could be your local network firewall blocking UDP traffic. |
Mini memory is fine (no other apps open), no firewall blocking UDP. It's a mystery.
Posted By: HenryM
Date Posted: 05 Mar 2019 at 5:03am
Could there be a setting on the trainer app or the IFD app that is not correct? You have to set up the correct device on both apps, and the correct IFD Chassis ID and iPad number in the IFD100 app (on the iPad go into Settings -> IFD Trainer and IFD100 to verify, I have bot chassis and iPad set to 1).
Date Posted: 06 Mar 2019 at 1:11am
Yep, mine setup the same way. Like I said, it's a mystery. Not a malfunction of certified installed equipment, so I regard this as merely an unsolved puzzle.
Posted By: dwbarnett
Date Posted: 06 Mar 2019 at 2:16am
Hi, I only have 1 ipad. Is it possible to use the PC trainer and Ipad networked, with the WIFI. If so would I set the PC trainer the same if I was using 2 ipads?
Also have a Stratus 2, anywayto set that up at home, to see how interactions might go. Thanks for any insight. Best, David
Date Posted: 06 Mar 2019 at 8:51am
No, the PC trainer won't work with the IFD100.
You can connect the iPad to the Stratus at home, but since there's nothing else on the network to talk to the IFD100, it would be pretty uninteresting.
Date Posted: 06 Mar 2019 at 10:52am
Thanks Steve, Had a hunch that was the case. Best, David
Posted By: edanford
Date Posted: 06 Mar 2019 at 11:53am
The Trainer does not work with IFD100 10.2.2.0.A . The code versions do not match.
Avidyne will have to release a trainer with SW version compatible with IFD 10.2.2.0.A.
In other words the system link got broken by the new IFD100 SW A version upgrade.
------------- Ed
Date Posted: 07 Mar 2019 at 1:56am
Steve Lindsley just posted on 4 March at 9:48 that "It should work, we run those two versions together all the time."
If you're right, though, that would explain why I can't get those versions of the Trainer and the IFD100 to work together.
Posted By: AZ Flyer
Date Posted: 09 Mar 2019 at 11:58am
It would be helpful to know which UDP and TCP ports the IFD100 and simulator apps are using. I have a DLink router and have the same problem as the others in not being able to connect the apps across two iPads. Knowing the ports being used should allow me to create rules to permit the necessary communication.
It seems obvious to me that the issue is with the router given that all of the other possibilities have been thoroughly discussed and eliminated in the posts above.
Posted By: AZ Flyer
Date Posted: 09 Mar 2019 at 12:49pm
I have confirmed that the DLink router is the reason I am unable to connect the IFD100 and trainer apps on two iPads. The reason I know this is that a few posts above gave me the idea to use my Stratus 2s as the wireless router, and that actually works to connect the two apps (a good use for the Stratus 2s, btw, as I haven't been using it since purchasing the current plane that has a Lynx installed with dual-band ADS-B in and reliable WIFI).
A few things to be aware of:
1) The IFD100 and trainer apps do NOT need to be the same version (as confirmed by AviSteve above). 10.2.2.0.A on the IFD100 and 10.2.1.0 on the trainer work just fine together.
2) Even with the same Jeppesen databases downloaded on the two iPads (or not downloaded at all, I would assume), you can't start one of the apps by logging into Jeppesen and not do the same with the other. BUT, you can just start both apps by not logging into Jeppesen and everything works fine. This is helpful because then you don't have to keep switching from an internet connection back to the Stratus 2s. Leave it on the Stratus 2s and bypass the Jeppesen login and it works just great.
3) Although both of my iPads are running the same iOS version (I'm still on 11.4.1 because of issues that keep popping up with the 12 generation), I suspect it doesn't matter at all if the iPads are running different iOS versions so long as they are sufficiently current to run the app versions properly.
4) I dislike intensely having to try to troubleshoot these kinds of issues, so I'm not going to bother trying to figure out why my DLink router won't let the two apps talk to each other. I'll just keep using the Stratus 2s as the WIFI server when I want to run the two apps together.
5) Avidyne produces great boxes and knows how to support the avionics functions of those boxes extremely well. However, when it comes to networking and WIFI issues, those clearly are not Avidyne's strong suit. I've had more problems with IFD boxes trying to get WIFI to work properly (one box finally had to be replaced because of a COM issue and that also resolved the WIFI issues I was having with that box), and that continues to the present where my current IFD keeps disconnecting from the Lynx WIFI network that I use to communicate with my iPad Pro and Foreflight. My experience is that Avidyne tech reps try their best to resolve these issues, but often with apparently incomplete information and insufficient technical background in network and WIFI issues, often suggesting causes and solutions that frankly don't make any sense in the networking/WIFI environment.
6) I'm liking this IFD100 functionality enough that I think I'll use the iPad mini running just the IFD100 app (as has been previously noted, trying to run the IFD100 app and Foreflight on the same iPad does NOT work well as bringing up one disconnects the other, so it is not a seamless solution).
7) BTW AviSteve, it would be very helpful if the IFD100 app could be configured to show more backup COM frequencies like the box does. I like to have at least three, and sometimes four, COM frequencies showing so I can enter in and select those as I'm moving through busy airspace. Presently, it does not appear the backup COM datablocks can be enabled on the IFD100 app.
EDIT: And why can't the local time offset be changed on the IFD100 app either?
Posted By: Bob H
Date Posted: 09 Mar 2019 at 9:41pm
Posted By: AZ Flyer
Date Posted: 10 Mar 2019 at 4:26am
Thanks, I do remember seeing that. It's still the few seconds delay that will drive me nuts because that's not how I'm accustomed to dealing with multiple applications, whether on a PC or an iPad.
