Terrain Alert - how to temporarily silence
URL: http://forums.avidyne.com/forum_posts.asp?TID=1121
Printed Date: 06 Jul 2025 at 11:33am
Topic: Terrain Alert - how to temporarily silence
Posted By: CardinalRG
Subject: Terrain Alert - how to temporarily silence
Date Posted: 04 Aug 2016 at 3:45pm
I'm looking for a way to quickly acknowledge and silence aural terrain alerts.  Currently the alerts continue until the terrain danger ends.  This is a problem in controlled airspace with high towers near by.  Bitchin' Betty often starts nagging during ATC communications, especially in control zones with high towers nearby (eg 1815 foot tall CN tower in CYTZ control zone)
Ideally, I would like to be able to press the terrain alert softkey to acknowledge the warning and thereby temporarily silence the aural alerts for 2 minutes.
I am not interested in disabling this feature nor fiddling with the set-up screen in flight to temporarily turn off the aural warnings.
A related but separate concern is that the dimmed night screen goes full bright during the terrain alert. This is akin to shining a flash light in ones eyes during night ops.
I suggest that the screen brightness setting not change during terrain warnings and that only the soft key or AUX keys go full bright or flash to get one's attention.
Date Posted: 04 Aug 2016 at 10:42pm
My understanding is that we'll be able to connect an external "audio alert" switch so that we can quickly and easily turn off warnings when desired without having to go through the setup pages.  I assume we'll still get the CAS alert.
Date Posted: 05 Aug 2016 at 10:27am
As an interim solution, you might try setting the Alerts Audio to a lower volume level. In my airplane, I have the ability to turn the alerts off from my audio panel if I want to.
Date Posted: 08 Aug 2016 at 3:47pm
Touch the terrain alert CAS message (or press the bezel CLR key) which instantly turns off the aural alerting (but keeps the alert lamp and map coloration).
