  New Posts New Posts RSS Feed - Install Question
Install Question
ddgates View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Topic: Install Question
    Posted: 11 Aug 2015 at 12:24pm
I already have TAS-605, Aspen PFD and MFD, and dual IFDs.
MLB-100 install underway.
Received from installer:
"Hello David,
Before changing the wiring, I wanted to verify that TAS600 will now be dedicated to the Aspen and MLB100 will be traffic and weather for the IFD540's"
I don't know what the answer should be.
Thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 1:14pm
Without question, pipe TAS600 traffic to both the Aspen and IFD540. Will you be getting the "A" upgrade?
The MLB100 can be set to send weather to the IFD540.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 7:02pm
Thanks, Orest.
Yes I will be getting the "A" upgrade.
You confirmed what the shop recommended.
