  New Posts New Posts RSS Feed - Avidyne SIL IFD540 OBS Calibration
Gary T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary T Quote  Post ReplyReply Direct Link To This Post Topic: Avidyne SIL IFD540 OBS Calibration
    Posted: 21 Oct 2014 at 8:41am
Avidyne SIL  # 606-00182-001 mentions a hardware Mod 2 if the OBS calibration error is excessive.
Should this hardware Mod be performed on all units currently in the field or only on a case by case
basis?  Is Avidyne currently incorporating this hardware change on all newer production units?
Gary-T
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2014 at 8:58am
Gary,
Are you on a mailing list for the SILs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary T Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2014 at 9:21am
Orest,
I am not on a mailing list for the Avidyne SILs.   I spotted this SIL on the
Avidyne.com web site under  Support,  then Downloads & documentation.
Gary-T
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2014 at 5:20pm
Avidyne recommends the mod be applied to any units in the field that exhibit the behavior as described in the SIL.   And we have cut the mod into production.
If you have a question whether you have HW mod 2 or not, call or send a note to Avidyne Tech Support and they should be able to look that up, even if you don't have your units serial numbers.
ddgates View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2014 at 10:34am
This is what my shop said:
"David's a/c is an arinc 429 installation(with the aspens) this does not apply there is no calibration, just confirmation on functional test of antenna and rf level to capture. Which has all been done. Thank you."
This page was generated in 0.182 seconds.
