AXP340 traffic/weather display options |
Post Reply |
Author | |
phkmn
Groupie Joined: 06 Feb 2013 Location: Chicago Status: Offline Points: 78 |
Post Options
Thanks(0)
Posted: 03 Jun 2014 at 2:42pm |
I currently have a deposit on the IFD540. My current xponder is the G330 which displays TIS traffic on my 530.
If I install the AXP340 with my IFD540, 1. Will the AXP340 display TIS traffic on my 540 when I'm in a TIS coverage area? 2. If I purchase a dual band portable receiver (e.g. Stratus II), I should be able to see both weather and ADSB traffic on my Foreflight-loaded Ipad? |
PH
oskrypuch
Post Options
Thanks(0)
Yes & Yes (the latter assuming that that is a 330ES).
I am getting a TAS605A in, so for me it will be academic shortly. Will be dumping my 330 "plain" for a 340 to get ADS-B compliant.
* Orest |
phkmn
Post Options
Thanks(0)
My G330 has not been upgraded to ES - no reason to do so if it won't accept position data from the 540. |
PH
oskrypuch
Post Options
Thanks(0)
Then, it is YES and NO.
Although you may see the occasional ADS-R traffic on the Stratus, it will be only if you are in the area of another aircraft that is ADS-B participating. * Orest |
phkmn
Post Options
Thanks(0)
But if I replace my Garmin 330 (no ES) with the Axp340, the answers are Yes and Yes?
PH
MysticCobra
Post Options
Thanks(0)
However, if you do have a separate ADSB-in device, then having the AXP340 will ensure that you get good traffic data into your receiver, since ADSB traffic data is only transmitted when an ADSB-out equipped plane "wakes up" the ground transmitters to provide traffic data. Depending on your ADSB-in device, you may or may not be able to display the data on your IFD540. Many of the solutions available today are uncertified and only work with portable electronics like iPads or Android tablets, such as the combination you mention in your second question. So, I think the answers to your questions are "NO" and "YES". Orest, am I missing something in my understanding of the AXP340?
Edited by MysticCobra - 26 Jul 2014 at 1:27pm |
oskrypuch
Post Options
Thanks(0)
Whoops, I didn't notice that phkmn was replacing his GTX330 with a 340, as I note I was assuming he had and was keeping a GTX330ES. The GTX330xx does have the older Mode S distributed TIS traffic, and will populate any device that can receive TIS on an ARINC429 bus. (as long as ModeS TIS remains available)
A 340 supplies NO ModeS TIS traffic at all, but by itself sending an ADS-B out signal on 1090, it will facilitate other receive-only devices to receive all the local traffic (TIS-B) from ground stations (ADS-R). Sorry to mislead. * Orest |
phkmn
Post Options
Thanks(0)
I guess I may as well stick with my existing 330 since I fly in the TIS area surrounding the Chicago Class B. And if the 330 won't accept position data from the 540, there's no reason to add ES.
Gee, saved some money. |
PH
oskrypuch
Post Options
Thanks(0)
Bonus!
* Orest |
Paul
Senior Member Joined: 17 Aug 2012 Location: Massachusetts Status: Offline Points: 285 |
Post Options
Thanks(0)
The Trig TT-31 has a TIS output. I wonder if it would work if it were connected to the IFD540.
Post Reply | |
Tweet
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You can vote in polls in this forum |
