  New Posts New Posts RSS Feed - ILS Procedure Fails to Arm Nav Source
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: ILS Procedure Fails to Arm Nav Source
    Posted: 31 Aug 2012 at 8:57am
While this may be an old issue, I can't find reference to it.
We are finding that the FMS will not always switch Nav Source from FMS to Nav on an ILS.  I thought I had read that it would only automatically switch on Vectors to Final, but even then it is inconsistent.
Am I doing something wrong, or have a misunderstanding?
Craig
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 7:13pm
Yes, I believe you are doing something procedurally wrong.  Let me dig up a previous explanation on 4 Sep and update this post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 1:49pm
Craig,
I may withdrawal my procedural indictment claim.   When I went back and looked at all previous reports of this behavior in the past, it seems to always be due to the station identifier Morse code not being properly decoded.  The logic behind it being that if we can't decode the station and compare it to the on-board database, then we can't be sure you're on the proper approach and don't autoswitch the nav source on you.
I suspect your system expertise makes it very likely that you're doing all the correct procedural steps.  Do you by chance recall if you saw the station identifier get displayed in English?  That English display is the indication that the identifier decoding has successfully happened.
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 1:07pm
Jake,
I will check that out on next flight.
Thanks for fixing my access.
