  New Posts New Posts RSS Feed - Bad radio reception
Bad radio reception
luchetto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Topic: Bad radio reception
    Posted: 21 Aug 2017 at 4:10pm
For whatever reason both the 540 and 440 radio reception quality has noticeably deteriorated after a magneto repair. I had a problem with the tower frequency 118.10 as I did not hear them when they called me. The reception was random so Zürich tower sent me back to the parking position as I was holding up the commercial operations. all other frequencies were ok.
I taxied back but didn't want to give in so I tried another headset and now I was able to hear the tower again. I convinced them that I had resolved the issue and asked to depart and reluctantly they let me go. All seemed ok but shortly after taking off the reception started to deteriorate. I was getting all calls but there was a rattling that was getting stronger the farther I was getting. When they allowed the frequency change I was barely able to read them. I never had this issue before. I have had a bad magneto which was repaired and now I have this radio issue. Could there be a connection between the two things? What can I do to resolve the problem?
Thanks for your help.
Placido
brou0040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 10:31am
http://forums.avidyne.com/forum_posts.asp?TID=1351&title=ifd-540-reception
AUXAIR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 11:10am
Yes, it COULD be related.  Aviation spark plug wires are shielded to reduce interference from the sparks created by the magnetos.  If the shielding was not properly re-connected or the wiring updated if deteriorated, then it could result in interference into the aviation AM radio reception
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 11:16am
Additionally -
To check to see if there is a problem, have someone take a hand-held aircraft radio and stand beside the aircraft as it is started.  (Keep out of the propeller arc!!)  What are the results on the hand-held?
If loud static is detected by the hand-held, further trouble-shooting can be done by having your mechanic take the handheld and see where the loudest static occurs in the engine area.  That might be a source of the problem.
David E.
Cessna 182 RG II
