ADS-B IN dual-band solution? |
Post Reply |
Author | |
compasst
Senior Member Joined: 22 Feb 2015 Location: Akron, OH Status: Offline Points: 169 |
Post Options
Thanks(0)
Posted: 18 Feb 2017 at 12:10pm |
Any recommendations and/or experience with dual-band ADS-B IN solutions that work with the IFD-540?
tony
Senior Member Joined: 06 Dec 2011 Location: Atlanta Status: Offline Points: 466 |
Post Options
Thanks(0)
My stratus 2 is dual band and works just fine
MysticCobra
Post Options
Thanks(0)
The OP asked for solutions that work with the IFD. I'm pretty sure you're not displaying your Stratus 2 traffic and weather on your IFD screen, right?
bellanca1730a
Groupie Joined: 04 Jul 2013 Location: Tampa Status: Offline Points: 63 |
Post Options
Thanks(0)
+1 Simpson, I drink the koolaid. Please bang this drum internally. As soon as Avidyne offers one, I'm buying. |
Sean Andrews
Bellanca Super Viking |
TogaDriver
Senior Member Joined: 23 Sep 2013 Location: United States Status: Offline Points: 133 |
Post Options
Thanks(0)
I think I read that 10.2 supports Capstone-compliant ADS-B in (GDL90 protocol).
Simpson, is this true? And if so, will it be on the serial or ARINC inputs? What setting would we use?
tony
Post Options
Thanks(0)
Of course not, I miss understood the question then |
TogaDriver
Post Options
Thanks(0)
It is worth exploring potential solutions, Tony.
If 10.2 will actually support the GDL90 protocol then it will be good to know what input it can accept (serial or ARINC or both). This, in turn, will possibly open up options in both experimental and certified markets for ADS-B inputs, since Capstone (GDL90) is open-sourced by the FAA and is not a proprietary format. |
ddgates
Post Options
Thanks(0)
As AviJake had pointed out previously, there are multiple flavors of "Capstone". I wish they had been standardized as was the intent of Captsone, but...
AviSimpson
Senior Member Joined: 31 Mar 2015 Location: Lincoln, MA Status: Offline Points: 765 |
Post Options
Thanks(0)
The support of the GDL90 Protocol will be over serial.
Avidyne Corporation Product Manager |
TogaDriver
Post Options
Thanks(0)
Thanks Simpson! Will the serial input take both FIS-B and TIS-B in the same GDL90 stream?
AviSimpson
Post Options
Thanks(0)
Yes indeed.
ddgates
Post Options
Thanks(0)
Simpson:
So if you have DUAL IFDs, an MLB, and a TAS-605, what is the best configuration? (Assuming 10.2) |
AviSimpson
Post Options
Thanks(0)
Per FAA you can't have dissimilar traffic on the same display. With that said, would have the TAS going to one IFD and the SkyTrax100 going to the other. Another option is to have both products going to one display but don't wire the traffic portion of the 100.
ronl
Groupie Joined: 08 Apr 2015 Status: Offline Points: 88 |
Post Options
Thanks(0)
Well then apparently the FAA didn't realize what L3 was doing with their Lynx system when they approved it. If I understand correctly, that system merges TAS (SkyWatch) and TIS-B traffic targets on the same display.
Ron L
Catani
Senior Member Joined: 21 Jan 2016 Status: Offline Points: 362 |
Post Options
Thanks(0)
Rather than assume somebody apparently failed, consider the possibility you don't have all the facts yet. Like, consider the possiblity that the FAA prohibits two independent traffic devices simultaneously feeding a third display device that wasn't designed to handle it. Thinking further, consider the Lynx is a single box feeding its own internal display, and has hardware and software that by purposeful design combines targets from various internal sources before feeding that display. Which of course the FAA has no problem with because the Lynx resolves all conflicts internally before displaying targets. Looked at that way, neither the FAA is stupid nor is Simpson wrong - a real possibility I think. I personally don't know, but I think it's safer and more fair to all involved to assume that with more facts the explanation may not involve any incompetence, just more familiarity with the avionics. Let's see what happens.
ronl
Post Options
Thanks(0)
Sorry if my post sounded snarky. I did not intend to be offensive or disrespectful to anyone.
I was just wanted to point out that, at least in this case, the FAA has allowed "dissimilar traffic on the same display". |
Ron L
AviSimpson
Post Options
Thanks(0)
Let me clarify as my post could have been slightly unclear. You can not have 2 different sources (for argument sake an Avidyne TAS and a FreeFlight ADS-B receiver as an example) going to the same display. The thought behind this is that the 2 different products derive their information in different ways (one is through the active interrogation of the transponder and the other is through the ADS-B network). This could cause 2 different targets to display for one aircraft, thus causing the operator to not know which one is the correct one.
If a source, like the L3 Lynx, does the merging before it sends the data to the display, then that's approved.
oskrypuch
Post Options
Thanks(0)
Just like the when the TAS6xx becomes the TAS6xxA. Two data sources (active + TIS-B) combined, but a single output to the display device. * Orest |
Post Reply | |
Tweet
