  New Posts New Posts RSS Feed - Certified
Certified
77Mooney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Topic: Certified
    Posted: 26 Nov 2016 at 7:44am
Will the DFC90 ever be certified for a Mooney?
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 11:44am
We don’t have any plans for certifying the DFC90 in the Mooney at the moment however, we are always evaluating projects, especially the DFC line.
TomH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 2:14pm
I remember reading about or hearing something regarding Part 23 re-write (maybe?) that would allow an existing STC to cover other airplanes not specifically listed provided they had the exact same avionics and setup. For example, a Columbia with Avidyne which has (nearly) identical physical equipment as a Cirrus of the same era. Can Avidyne comment on that? Because there are a worthwhile chunk of Columbia/Cessna drivers that would jump on a DFC90 if given the opportunity.
I suspect the answer will include "it's not that simple..." but I thought I'd ask.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 8:11am
Thats too bad. I would like to install it in my plane... :( :(
