deleting waypoints on STAR |
Post Reply |
Author | |
jbeasley
Newbie Joined: 22 Sep 2016 Location: 7WI5 Status: Offline Points: 6 |
Post Options
Thanks(0)
Posted: 25 Sep 2016 at 4:11pm |
Good Afternoon, I loaded the STAR for KMKE and starting from KMSN (about 90 miles East), wanted to go direct to one of the nearer waypoints. But the system wouldn't let me delete the further out waypoints. Have others had this issue? How it is best handled? Thanks for any help, John |
Ibraham
Senior Member Joined: 21 May 2016 Location: KHWO Status: Offline Points: 357 |
Post Options
Thanks(0)
I just tried that flight from KMSN to KMKE on the IFD simulator. If you are vectored to join the STAR, then select the waypoint at the end of the leg you are joining and push Activate Leg.
After BONOT, it will keep you on a heading of 74 since according to the STAR you should expect radar vectors to the final approach course unless you select an approach after BONOT then you can connect the GAP. |
mfb
Senior Member Joined: 20 Dec 2014 Location: KATW Status: Offline Points: 293 |
Post Options
Thanks(0)
Ibrahim's procedure sounds good to me.
The short answer is that arrival procedures, departure procedures, and approaches are "fixed." You can't add or delete waypoints. If you don't want the entire procedure you have to skip waypoints by going direct at the appropriate time. Mike Edited by mfb - 25 Sep 2016 at 7:39pm |
dmtidler
Senior Member Joined: 12 Feb 2016 Location: USA Status: Offline Points: 616 |
Post Options
Thanks(0)
I think a "no transition" option would be a great feature for SID/STAR entry on the IFDXXX. The "no transition" option for SID/STARS has been available for Boeing & Airbus FMC/FMGC route programming for the past 20+ years.
If a SID/STAR transition is not entered, then the SID/STAR routing would terminate/begin at the end/beginning of the common routing for that SID/STAR. |
jbeasley
Post Options
Thanks(0)
My thanks to all who responded! John
jimmyz80
Groupie Joined: 24 Jul 2016 Location: Folsom, CA Status: Offline Points: 86 |
Post Options
Thanks(0)
Not to mention the Garmin products support "no transition" SIDs/STARs as well. Seems like Avidyne is the odd-ball here.
Post Reply | |
Tweet
