Forum Home Forum Home > Avidyne General > AMX240 Audio Panel
  New Posts New Posts RSS Feed - Multiple BT devices?
paulr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Topic: Multiple BT devices?
    Posted: 14 Apr 2016 at 8:30pm
My co-owner and I each want to pair our phones with the same AMX240. Is that possible, or does the pilot flying have to re-pair his device for each flight?
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 8:48am
Do you want to be paired at the same time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 8:50am
I want them both paired (e.g. so the AMX240 knows they exist and will connect), but only one will (usually) be in the plane at a time, and it's OK if only one device at a time can be active. Right now Derek's flying, so he wants his phone paired and active. When I pick up the plane later today and take it to KNEW, I want my phone paired.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 11:14am
Your (and your co owner) phone should remember and be able to connect to the audio panel when the audio panel is on. This is more of a phone feature than the audio panel. You can't both have your phones connected to the audio panel via bluetooth at the sametime.
This page was generated in 0.113 seconds.
