  New Posts New Posts RSS Feed - COM/NAV standby datablock setup
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Topic: COM/NAV standby datablock setup
    Posted: 26 Feb 2016 at 9:05am
First flight yesterday with my new IFD540. I'm still processing a lot of what I learned. Pretty neat piece of equipment!
One simple question: the POH says, on page 4-22, that you can add two "Com/Nav Standby" datablocks to the left datablock area. When I try to do that, those choices don't appear if I select any datablock position other than the "VLOC Radio" position. I am guessing that's by design; otherwise you could set up a config that looks like this:
COM1
COM2
NAV1
NAV2
COM3
COM4
which might confuse people.
If this is by design, perhaps the POH should be updated to reflect it. If it's not by design, what am I doing wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 9:54am
I'm not sure I totally follow but here is what the IFD540 is designed to do in the case of multiple standbys config:
COM1 / NAV1
COM2 / NAV2
COM3 / NAV3
COM4 / NAV4
When you select multiple standbys, the default will be all COM freqs. To access the NAV freq. press in the left knob. This will toggle to the list of all NAV freqs. including all the NAV standbys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 10:02am
Maybe this picture will help. It's the default factory config: COM1 active (#1)/standby(#2) and NAV1 active/standby, with blank space below. I want to add a 3rd or 4th standby for COM1. There doesn't seem to be a way to add it to the blank area because, when I select those slots in the datablock setup page, the 3/4 standby options don't appear. What am I missing?
datablocks
Post Options Post Options   Thanks (0) Thanks(0)   Quote pburger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 10:07am
I'm not sure how it is described/shown in the manual, but yes, you can put all those standby frequencies in there, and yes, it is a little confusing.  You have to choose between two scenarios:  Either you will have both COM and VLOC displayed at the same time - as in your posted pic, or it will be all COM or all VLOC.
If you want to see both COM and VLOC frequencies at the same time, you would have the standard COM active/stby frequencies in the upper left, then choose VLOC Radio below that to see the VLOC active and standby.  In that scenario, you press the lower left knob to toggle between the COM standby or the NAV standby frequencies.
OR..... instead of putting the VLOC Radio below the COM, you put up to three more standby frequencies under the COM active/stdby frequencies.  You will then see the COM Active with up to four COM standby frequencies.
When you push the lower left hand knob, the frequencies toggle to the VLOC frequencies, such that you have the active VLOC with up to four VLOC standby frequencies.
Edited by pburger - 26 Feb 2016 at 10:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 10:12am
Thanks, pburger-- that's exactly what I wanted to know. This is not at all clear from the manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 11:53am
Thanks for posting the pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2016 at 9:00am
Here is what I did to support situational awareness...
I set up three COM frequencies (Active, Stby1, Stby2) which means that no NAV frequencies are normally visible, but then I put the "Decoded VLOC IDENT" information as permanent left-side datablock.  So even if I can't see the NAV frequency all the time, I can see the station identifier all the time.  (I also have the Nav Mode in there, but if I gave that up then there would be enough room for four COM frequencies and still have the VLOC IDENT information displayed.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 7:09pm
While flying over the weekend, I noticed that I don't quite have it correct in the image I posted here.  I have the Decoded VLOC IDENT immediately under the frequencies, and then the Nav Mode below that (followed by Desired Track, then Actual Track, both small one-liners).
This page was generated in 0.064 seconds.
