  New Posts New Posts RSS Feed - Map Orientation 540
Map Orientation 540
Suskej View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Suskej Quote  Post ReplyReply Direct Link To This Post Topic: Map Orientation 540
    Posted: 15 Oct 2015 at 7:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Suskej Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 7:29pm
Sorry for the miss post but her his the rest of the message.
I am operating a 540 running ver 10.1.0.0  the map orientation is grayed out in the user setup page and I cannot get the unit to change map display orientation at all.  It states the it is set for "Track Up" but displays "North Up" and this cannot be changed.  Also the display cannot be changed to "ARC" mode it is stuck in 360 degree display mode.  Any suggestions ????
Gring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 8:17pm
The User Setting you are referencing allows you to use either GPS track or Aircraft Heading for the MAP.  In order to use Heading, you need to have avionics that will provide the IFD540 heading information ie Aspen, KCS55 HSI, etc. with heading output.  Since it is greyed out, you either don't have that type of equipment, or it isn't wired, or it isn't setup properly.
To change the orientation of the MAP, you simply push the lower right small knob to cycle between North Up, Track up Arc, Track up (centered).
Edited by Gring - 15 Oct 2015 at 8:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 8:35pm
Originally posted by Gring Gring wrote:
The User Setting you are referencing allows you to use ...
This really is such a common new user issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Suskej Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 8:54pm
Well I might be a new user, but I know that turning the small right hand knob "Should" change the display but it does NOTHING !!!!
Thats why I posted the question, seeing that it states that it should do something in the manual...
Also a reset of the unit still does nothing.  I guess I am asking if there is some setting that is in the install menu pages that need configured.
AUXAIR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 9:20pm
It is not turning the small right knob that changes the map orientation, it is pushing the small right knob that changes it.
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 9:46pm
Originally posted by Suskej Suskej wrote:
Well I might be a new use...
Not really a slight on you. It may be a documentation issue.
