  New Posts New Posts RSS Feed - IFD to Garmin 330 xponder
310pilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 310pilot Quote  Post ReplyReply Direct Link To This Post Topic: IFD to Garmin 330 xponder
    Posted: 04 Aug 2015 at 11:40am
Just wondering if anyone else is experiencing the same problem. The Garmin xponder relies on GPS groundspeed to automatically go from "Alt" to "stby" mode after landing. This communication is not happening and therefore no auto switching to stby. The transponder uses different logic to go from stby to Alt on takeoff so that portion is working fine.
Also, a reminder that still no "Traffic Not Available" message on the IFD when outside of TIS-A coverage area
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2015 at 2:46pm
The GTX330 transitions from the Flight Timer, not the GPS groundspeed. The Flight timer can be controlled by several sources (one being GPS groundspeed) however, it depends on configuration and wiring. I would double check the configuration on the GTX, the specific config you are looking for is on 5.2.8.
