  New Posts New Posts RSS Feed - Fuel Range rings on  a IFD 440
pat@werigi.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pat@werigi.com Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Range rings on a IFD 440
    Posted: 25 Jul 2015 at 12:53pm
Just installed twin IFD 440's in a Cirrus (plug and play), will the fuel rings display without any additional hardware changes?
If not what is needed? If so, how do I enable?
Pat
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 1:08pm
Not yet but we have that on a list to do for a future software upgrade.   The IFD does not look to use the fuel output values of the SIU/DAU unit in your Cirrus - it is only able to take input from dedicated fuel flow/qty systems or FADC units.   That's something we expect to change via the software release so your datablocks can show fuel, your fuel range rings can show up on the map and the FMS fields that show estimated fuel remaining at a flight plan waypoint get populated with data.
