  New Posts New Posts RSS Feed - How is this possible
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Topic: How is this possible
    Posted: 28 Jun 2015 at 3:02pm
My setup is a dual IFD 540 with Aspens and a Garmin GTX330 (no ES).
Today I was flying and I saw traffic. Often it will give a squawk code. Today, however, I saw the call sign.. N90VK .. an old Commanche.
How is this possible??? I thought this was a specific ADS-B function?
fritz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fritz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 3:40pm
Do you have TAS 6XX installed?  If so I believe it will display that information from Mode S targets.
The TAS6XX will display tail number information if the following requirements are met:
  1. U.S. registered aircraft
  2. The target aircraft must have a Mode S Transponder
  3. Avidyne display
Edited by fritz - 28 Jun 2015 at 3:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 4:50pm
Right.  The IFD540 will display tail numbers when that Mode S data is available to it.   It's all about the Mode S function which has no dependency on ADS-B.
TogaDriver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TogaDriver Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 11:13am
Just curious here:
How is it that you support TIS-A traffic but cannot yet display TIS-B traffic from the MLB100?  I'm guessing it's something to do with FAA approval.  This feature, which I believe did not make it in 10.1, is the trigger for me ordering the MLB100.
This is because weather, which I can get on my iPad is, for me, a strategic tool but traffic is an immediate, tactical, benefit and I want it front and center on my IFD.
I hate to even ask, but do you have TIS-B support locked into a particular release yet?
And I LOVE the single-line FMS display feature in 10.1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 7:17pm
Complexity and time to the finish  line.  Had to triage some items.
Just curious here:
Yes but not one I'm willing to talk about yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:16am
Jake,
I know the MLB100 can output data in a variety of ways.
Will the IFD process TIS-B traffic (from the MLB100) on the same serial data input that currently provides the FIS-B weather?  My understanding of the ARINC 429 standard format is that it only supports the TIS-A traffic, but I could be wrong about that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TogaDriver Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 10:34am
Just curious here:
Understood. I respect that.  TIS-B support is #1 on my wish list now.
This page was generated in 0.203 seconds.
