  New Posts New Posts RSS Feed - Heading bug is AVAILABLE now
Post Options Post Options   Thanks (1) Thanks(1)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Heading bug is AVAILABLE now
    Posted: 27 Jun 2015 at 11:40am
Well, did some more avionics work and with the changes in the ASPEN install manual, the shop was convinced to direct feed the 429 output to the IFD540. It still supplies the ACU2, but now Y's before it to go to the IFD.
The cool thing about this "heading bug", is that it mirrors the ASPEN heading bug only while the autopilot is in raw heading mode, when switched to GPSS, the heading bug on the IFD reflects the GPSS derived heading steer.
Edited by oskrypuch - 27 Jun 2015 at 4:03pm
Jack Seubert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack Seubert Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2015 at 2:33pm
Orest,
Do you know what version of the Aspen IM was used?
Jack
Jack Seubert
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2015 at 4:06pm
Not sure of the release/version of the IM. There was a change very recently in the language regarding this point, one of the threads here alluded to it. That said, it still remains a little open to interpretation, I had to do some convincing.
My shop mused that the basis for the initial restriction (during ASPEN certification) was that older avionics may not have been able to deal correctly with the plethora of data that was fed out.
Edited by oskrypuch - 27 Jun 2015 at 4:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2015 at 4:32pm
Orest:
So you branched the 429 output - one to the ACU2 and one to the IFD?  Is that right?
The same would then be doable if the ACU were an ACU1, right.  Would that not provide baro alt as well??
DMG
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2015 at 6:18pm
Correct, and Yes & Yes!
The ACU(2) itself does need the 429 data as well.
I still benefit from the ACU2 in my particular setup, because of the limitation of only one airdata input allowed on the 232 channels, a 430W holdover. But, that limitation is on the books to disappear as well.
Edited by oskrypuch - 27 Jun 2015 at 6:22pm
Royski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Royski Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 11:13am
It looks like the relevant part of the Aspen installation manual is section 8.2.6, Aspen document A-01-126-00 Revision H, page 82-225.
The ACU transmits the following labels on P3 pins 4 and 5 for GPS receivers and
systems that require low speed ARINC 429 magnetic heading and selected course.
ARINC Label                          PFD Data
Label 100                              Selected Course
Label 320                             Magnetic Heading
