  New Posts New Posts RSS Feed - Single Row Flight Plan Configuration
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Topic: Single Row Flight Plan Configuration
    Posted: 26 Jun 2015 at 2:02am
I am trying to figure out where to configure the flight plan page so that unselected legs are single row. The pilots guide says something about this on page 2-4. It says to find the setting in the FMS setup page in the AUX tab. But I could not find that in the 10.1 simulator. Could someone snap a pic of where you configure this?
From page 2-4:
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 2:05am
I guess I need to figure out how to post images too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 5:34am
Right. Page 2-4 (IFD540 version) shows single row flight plans in action. Page 4-35 shows the FMS Setup page where this is done. When on the FMS Setup page, twist the outer ring of the bottom right knob ( or use your finger to pan down via touch) to scroll down to that selection item at the bottom of the page. Then use the inner ring of that knob to turn the option on.
To add pictures, use the little arrow icon that points up and right to expand your edit options in the forum edit mode. That will display more icons and the tree one is the one to use to add pix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 10:09am
Thank you!
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 12:14pm
I have the newest simulator on iPad (10.1) and I don't see the option to turn single line on/off within SETUP >  USER OPTIONS.  Can you assist?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 4:46pm
That selection is on the FMS Setup page, not the User Options page.
Press AUX button then select the SETUP tab along the bottom, then press the "Setup" line select key along the left edge (see picture with red oval highlight) until "FMS" is displayed.  Then scroll down to the bottom of that page for the single row option on/off selection.
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 5:56pm
Mine still says Map update there.
My simulator is version 10.1 from the app store.  Says its the most up to date.  On the sys page it says May 26, 2015.  There is no update through appstore.  How did you get it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 6:01pm
Press that button where you see map and it will toggle to FMS
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 7:14pm
Wouldn't toggle off user options. uninstalled and reinstalled. All working now.
Is there a way to toggle all lines from single line to multi line without going through the setup screen?
Also, wind vector data block is not populating.  that a limitation of the simulator?
Edited by cavu - 01 Jul 2015 at 7:17pm
This page was generated in 0.118 seconds.
