  New Posts New Posts RSS Feed - A couple of minor potential bugs
Royski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Royski Quote  Post ReplyReply Direct Link To This Post Topic: A couple of minor potential bugs
    Posted: 27 May 2015 at 11:26am
So far I love the IFD-540 but after about 50 hours behind it I've noticed a couple of small but annoying issues. My installation has the current 10.0.3 software, an Aspen PFD, and a Shadin Miniflo-L fuel computer.
(1) The air data calculator defaults to an altitude in the flight levels (I think it's 27,200 feet but I wouldn't bet on that, I just know it's much higher than my service ceiling), shown in green text.  The Pilot Guide says "data fields in the various IFD calculators will be populated automatically with sensor data in green if it is available."  I'm not sure where the value is originating, but it is clearly wrong.  Maybe we can use GPS altitude here in a future software release?
(2) Based on what the Shadin is telling me for fuel reserve at destination, the 540 is incorrectly reporting the next waypoint as the destination in the GPS serial data.  This worked correctly before when I had my KLN-94 GPS installed. The fuel information on the IFD-540 itself is accurate (correctly shows fuel remaining at destination).
roltman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roltman Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 12:30pm
While I don't have the Aspen PFD, I do have the Miniflo-L and I have not seen what you are reporting on #2 after making several trips up/down the east coast via airways the intermediate waypoints and the destination have been reported correctly on both units.
Maybe this will help narrow down your issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pburger Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 12:33pm
On point (1), mine populates with the pressure altitude which is coming serially from my encoder.
jhbehrens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhbehrens Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2015 at 2:41am
On point (2) check the install manual as there are settings in the IFD's setup screens for sending either the next waypoint or the destination to your totalizer.
Edited by jhbehrens - 28 May 2015 at 2:41am
