  New Posts New Posts RSS Feed - VSR (Vertical Speed Required)
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Topic: VSR (Vertical Speed Required)
    Posted: 05 May 2015 at 5:50pm
Does the VSR value appear on the actual 540 when shooting an approach?  On the simulator it only appears when there is an altitude restriction ahead.
Would be nice to see the VSR for the approach (already adjusted for tailwind, etc)
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 5:52pm
Currently only exists when there is an altitude constraint ahead.  There is a candidate feature in the database to provide what you ask for.  It's a middle of the priority stack item now.
cavu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cavu Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 6:45pm
