  New Posts New Posts RSS Feed - Avionics shop refuses to activate ADS-B out
Craig767 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Topic: Avionics shop refuses to activate ADS-B out
    Posted: 21 Jan 2015 at 11:33am
Installed a IFD-540, AXP-340 and 240. My Avionics installer will not activate the ADS-B out of my AXP-340 because of STC. He feels until the STC for the ADS-B out is approved he cannot legally activate it. He has disabled the GPS position feed from the 540 to the 340. Tried to make the argument
that I paid for this feature and a safety of flight issue, but he will not budge. Did any of you that have the ADS-B out have any problems with installer. Any suggestions on how to get the ADS-B functioning.
roltman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roltman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 11:56am
I was just told the same thing when I go tomorrow for my APX-340 install. I need to produce paperwork to show FAA is okay with this.
Steve, do you have anything from the FAA on this topic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 12:03pm
They are misunderstanding the nature of that STC. That may take some arm twisting, or some head banging.
I am activated, and check out fine at the faa.gov email.
Gary T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary T Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 12:31pm
My installer activated ADS-B for me, but they were concerned about lack of STC available.
My ADS-B checked fine with the FAA compliance as well.
Gary-T
ddgates View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 1:11pm
Me too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 1:34pm
The STC is still in progress (probably still a month away) but....
Until proven otherwise, the Avidyne position is that everything can be installed and configured now.   You will be recognized as a valid ADS-B participant by the network now.  There is no restriction that prevents you from donating your aircraft data to the ADS-B network right now.  There is no mandate to be a particpant until midnight on 31 Dec 2019.  At that point, if the FAA were to audit you, you would need to produce FAA approved documentation showing compliance.
So we believe the installer concerns are excessively conservative.
MysticCobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 3:15pm
Remind your installer that there are certainly hundreds, probably thousands, of folks flying around with portable (read: not certified) ADSB-out devices in their aircraft, and the FAA knows all about them (since they're actively broadcasting their identity to ATC).  I'm talking about things like the SkyguardTWX, SkyvisionXtreme, etc.
I have a SkyguardTWX with (uncertified) ADSB-out, and have participated in the FAA's offer to "check the compliance of your ADSB-out solution".  Here's the first reply I got from them:
Originally posted by 9-AWA-AFS-300-ADSB-AvionicsCheck@faa.gov 9-AWA-AFS-300-ADSB-AvionicsCheck@faa.gov wrote:
Requested report attached.  Per FAA policy, portable transceivers should be configured to transmit a System Integrity Level (SIL) = 0 (ref. page 4 of report) to prevent data transmitted by uncertified ADS-B avionics (including GPS) from being processed by ATC and other ADS-B In equipped aircraft.  Please contact Skyguard for information to configure your transceiver to transmit a SIL of zero.
I don't know if current AXP340s are broadcasting SIL=0 to reflect their uncertified status, but even if they aren't, that's not breaking any law or violating any reg that's going to get anyone in trouble.
Edited by MysticCobra - 21 Jan 2015 at 3:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 3:59pm
Thanks everyone. Will share this with my installer to try and gently persuade him to change his mind.
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 4:19pm
Well I would try this argument....
The TSO'd transponder was installed on a 337 first.  Then after that installation, the IFD540 was installed with an STC per the FAA approved installation manual.  In that manual on page 177, it clearly shows an RS 232 wire going to your transponder.  If he doesn't follow the installation manual then he is violating the STC.
Worth a try.  If he wont hook it up, now will he do it later at no charge?
Sometimes hanger fairies connect wires......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 4:24pm
Hi Tony,
From what I understand the wire is connected and functions, but he has disabled the feature in the 540 maintenance menu. Maybe finding out how to activate it from maintenance menu if cannot persuade him to activate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 5:43pm
He probably disabled it by disabling the RS232 input in the AXP340 on the maintenance pages. That is a pretty easy fix. We can probably walk you through it, but be aware that your wings may fall off.
I don't believe that there is a setting to disable the output in the 540, as long as the wire is connected, the data will go. You have very easy access to all the maintenance setup screens in the 540, they are in the group of pages you see when doing a database update.
Edited by oskrypuch - 21 Jan 2015 at 6:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2015 at 6:32pm
Thanks, will take you up on the offer if he does not listen to reason.
Originally posted by oskrypuch oskrypuch wrote:
He probably disabled it by disabling the RS232 input in the AMX340 on the maintenance pages. That is a pretty easy fix. We can probably walk you through it, but be aware that your wings may fall off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 1:47pm
Well none of the aruguments worked. He is afraid that during a FAA audit they will question the work order for something that has no STC or field approval. Whether founded or not, he is afraid of a $10,000
fine. Of course you may ask why have a work order, but not my call I guess. So my options are wait a month of so to use a feature I want and paid for or try to get the ADS-B out activated myself. Right now the 340 shows no GPS position from the 540. Installer says 540 connected and it works so either turned off in some menu of 540 or 340. So if anyone has a ideas I would greatly appreciate them.
Also would advise those getting this install to verify with installer they will activate ADS-B out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 5:02pm
ONLY IF YOU ARE HANDY WITH ELECTRONICS AND SUCH ...
Going ahead, you could mess up your transponder settings and have to visit the same shop to fix it! Further, if it doesn't pass validation (faa.gov email check), then you will also have to return to the shop.
The input settings required in the AXP340 for the GPS location are TRIG ADS-B protocol and 9600 baud, these are likely set to something else to disable it. Grab the AXP340 INSTALL manual, turn to page 20, you will see it listed there.
Page 27 tells you how to get into the maintenance mode.
You also need to set what ADS-B IN (UAT or 1090ES) you are utilizing, I expect that is largely the point of this exercise for you, that you want to see traffic on a portable device.
Edited by oskrypuch - 22 Jan 2015 at 8:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 5:32pm
As someone else mentioned, if you're feeling philanthropic, you can set your ADS-B IN to "both" so that traffic data is broadcast on both freqs.  That would benefit nearby aircraft who have either UAT or 1090ES ADSB-in, but no OUT to trigger the broadcast.  (In practice, I'm not sure how many planes might have 1090ES IN capability without also having the OUT.  For UAT, we know that lots of GA folks are in that boat.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 6:03pm
Aircraft in avionics shop now, will try this when it returns. From what they tell me entire RS232 disabled as 340 air/grd logic does not work either.
The input settings required in the APX340 for the GPS location are TRIG ADS-B protocol and 9600 baud, these are likely set to something else to disable it. Grab the AXP340 INSTALL manual, turn to page 20, you will see it listed there.
Edited by Craig767 - 22 Jan 2015 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 6:05pm
Will set both anyway as have dual ADS-B in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 7:17pm
There is a separate "squat switch" line that should be connected to the AXP340 from the 540. According to a direction in a SIL, due to some logic issues in this when compounded with a GPS failure, the SIL directs to disable this until 10.0.3 is out. That may be what they are referring to.
Often transponders can pick up the ground/air state by monitoring the ground speed on the regular RS232 line (that is separate from the squat switch line), but I don't believe that the AXP340 actually does that.
Edited by oskrypuch - 22 Jan 2015 at 7:17pm
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 8:38pm
If the installer didn't follow the installation manual, I would hope you can document that and report it to avidyne. Hopefully Avidyne will take the appropriate action...
It definitely is not in avidyne's best interest to have renegade authorize installers out there. Right Steve?
If you can't tell, this just pisses me off. This is unnecessary regulatory bs.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 8:38pm
I don't think it works that way.  If your transponder says you can receive on both frequencies then the ground radar can send you the data on whichever frequency it prefers.  And it will know that you can pick up aircraft on both frequencies directly so it doesn't need to repeat anything.  Most of the time the only things it will need to send would be the locations of aircraft with Mode C transponders.
If you want to maximize the number of people who might be helped by the ground broadcasts aimed at you then you'd pick UAT only.  Portable ADS-B in devices receive UAT because that's where the weather is.  Some receive on both frequencies but I don't think there are any which receive only on 1090.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 8:47pm
Interesting perspective, but are you certain of the above, or just speculating?
It would seem more logical that if set to both, the system should assume an ADS-B IN reply is required on both. If not, then there would be no way to activate reception on both a portable UAT and panel mount 1090ES (like the upcoming TAS60xA units)
Edited by oskrypuch - 22 Jan 2015 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 8:52pm
It's baloney.  This particular installer sounds excessively conservative and unwilling to listen to logic.
I don't like this but realistically, I'd say either get a new installer or wait another month-ish until this is OBE.
Edited by AviJake - 22 Jan 2015 at 8:53pm
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 11:13am
Orest,
You could be right.  But sending on both frequencies would conflict with one of their goals (as told to me by someone involved in the design) which is to minimize 1090 activity.  1090 occasionally gets overloaded in some places.
I can't find a sufficient description anywhere.  Maybe Steve or someone at Avidyne knows the answer.  If not I'll try to find out elsewhere.  It would be interesting to run a test but it requires an airplane with a UAT transmitter and one with a 1090 only receiver and I don't have either of those.
Royski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Royski Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 12:34pm
FWIW, my installer said someone at Avidyne told him that the ADS-B should not be enabled until the STC is released.  Hopefully this will be moot point very soon.
topogen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote topogen Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 4:39pm
Interesting points...
My installation (just done last week) has a fully functional AD-B and I'm off to the races.  Florida shops understand the reality of on the cusp STC and act accordingly.... I guess risk aversion is alive and well in some avionics shops.... sheesh... wake up installers!
Not all that counts can be counted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 7:57pm
I was under the impression that if you had a dual ADSB in you would want both active for the times you are not in contact with a ADSB tower you could receive either a aircraft with UAT or 1090 out directly.
Edited by Craig767 - 23 Jan 2015 at 7:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 10:32pm
Sure.  I don't think anyone has suggested otherwise.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 11:38am
So far people haven't been naming the avionics shops that won't enable ADS-B out.
Perhaps we should have a new topic where we describe our experiences (good or bad) with installers?
Before I create such a topic I want to hear from Steve.  Is this an appropriate topic for Avidyne's forum?  It is likely that people will say negative things about some shops and I don't want to start something that will harm Avidyne's relationship with their dealers.
Gring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 12:28pm
Here is my perspective on it FWIW.  Since the STC will be out shortly 30 days? it probably is a moot point at this time.  To be fair to the installers, yes, as unreasonable as it is, the ADS-B out requires an STC, and if you subscribe to the FAA notices, you'll see fines levied against companies for using unapproved parts or installing in an unapproved manner, so their fears are not unfounded.  Do I think anything will become of using ADS-B without an STC now? - No.  I would simply ask your installer to wire the boxes as the installation manual prescribes to ensure the only changes are software setup.  I would ask which output was used and then...That way, you assume the liability and responsibility if you choose to do something different.
Getting frustrated at the Avidyne dealer doesn't really accomplish anything and the issue should be solved shortly.
I hope this helps to put it into perspective.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 1:19pm
Personally, I would concur with Gring's post.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 1:35pm
Actually my comment was more general.
I have picked my installer and they will start next Monday(!)  But I would have found any PIREPs useful in making my decision.  So I wonder, as more get installed, if there should be a topic for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 1:52pm
Well, there are plenty of spaces to discuss/diss bad installers. I doubt that a manufacturer would want to see threads like that on their own forums, but that is up to them of course.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 3:59pm
Orest,
I agree.  But other companies, at least other avionics companies, don't run a forum like this at all.
My attempts with Google to find avionics PIREPs didn't turn up much.  Where do you find them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 4:03pm
You may try the forums for more expensive airplanes like Beechtalk, COPA for Cirrus, and MOPA for Malibu/Meridian/Matrix owners.  These forums are generally full of people willing to spend money (especially your money) and they have knowledge of good shops and poor shops.  I can tell you from my experience, NexAir and VIP in the NorthEast have been very good.  Lots of good pireps from Gulf Coast, JA Air Center, Sarasota Avionics.
There are lots of horror stories out there about shops not doing the job right and leaving the owner to have it sorted out elsewhere.  Do your homework so you don't get burned.
Edited by Gring - 24 Jan 2015 at 4:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 4:32pm
Just like a lot of things...
word of mouth is a good thing.
In my case I used a well known shop but one who had not done the Avidyne 540/340/ or PMA450.
They were willing to charge me standard shop rates and not expect me to fund their entire learning curve.
I wouldn't go to a small shop, no matter how convenient geographically, that hadn't done these type of installs,  and pay for their learning curve or their mistakes.
That said, there are some lack of clarity points for an installer in the 540 IM.
Edited by ddgates - 24 Jan 2015 at 4:33pm
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 5:30pm
We're straying from the topic quite a bit, but Nexair is doing the install for me.  I also got a quote from VIP but Nexair's proposal was a bit closer to what I had in mind and they were more prompt in getting back to me.  In a couple weeks I'll know if it was a good decision and whether or not ADS-B out is enabled.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 7:26pm
My friend who really knows ADS-B says that currently they are transmitting on both frequencies if an airplane says it has receive capability for both, but that it could change.
Meanwhile they are predicting 2-3 feet of snow for us but our plane is in the nice avionics shop hangar having an IFD 540 installed instead of being tied down outside on a pad.
hamilton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 2:31pm
Back to the top, the shop may have disabled it in the 540 as they mention by not setting the channel output of the IFD to the AXP as ADSB Avi.
I think the best option is to wait.
Here in New Zealand we cannot install a mode S capable transponder without an STC (we do directly accept FAA STCs thank god) so we are all waiting with baited breath for that magic piece of paper!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 3:20pm
But Avidyne already has the mode S STC.
They don't have the STC for the ADS-B using the 540 as position source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 3:48pm
When installed along with a Freeflight 1201 yes, not as a standalone installation or any other form of position source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 4:08pm
Respectfully, I don't think that's right.
Avidyne has the pure mode S STC (for the US FAA) else it couldn't be in my panel, and it is there
They don't have the paper saying the 540/340 combination together satisfies the 2020 ADS-B requirement.
That's how I understand it.
Jake?
brou0040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 5:21pm
That is not what Avidyne's own tech support believes.  While on the phone with tech support after another GPS failure (I'm at 100 failure rate with the 540, the unit has not yet functioned for an entire flight without failing) , I was told that I needed to turn off sending the ADS-B signal to the AXP340 since it is not yet STC'd.
chflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 1:19pm
Jake?
Do you have the STC number of the Avidyne pure S-mode STC? I haven't been able to find it. Is it only for one a/c or does it have an AML?
Another thread has a discussion about the pure S-mode installation being a minor alteration (or not) and Steve hasn't mentioned anything there about an STC for pure S-mode.
I'm not sure how the ADS-B STC will address this question since, as you mention, it will just cover the use of an IFD540 as GPS source and the 2020 ADS-B requirement, and not the AXP340 installation as a straight S-mode transponder.
Edited by chflyer - 04 Apr 2015 at 1:19pm
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 9:26am
Exciting news from the FAA this morning...
The AXP340 received it's AML STC for ADS-B Out w/ R9, IFD540 and GNS430Ws/530Ws!
TogaDriver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TogaDriver Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 9:37am
Great news to greet my morning coffee!  Thanks!
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 10:48am
That's great news!
Since our plane has a field approval for the IFD 540 / AXP 340 combo does this affect it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 10:55am
This STC gives you something to point to for the ADS-B Out Mandate Compliance in 2020.
Edited by AviSimpson - 09 Apr 2015 at 11:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 7:06am
David,
Could you indicate the STC reference? (should be on the 337 that was filed)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 7:15am
Vince:
I will look (will be a few days -boarding the aluminum tube at the moment). Maybe AviSimpson can track it down in the interim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 7:40am
I've just found the new AXP340 STC (incl ADS-B) on the FAA web site, and it also covers the basic A/C/S transponder function, so don't worry about looking for the previous one Dave.
BTW, the new AXP340 ADS-B Out STC is SA00352BO. It includes an AML. I don't see this up on the Avidyne web site yet (at least not under AXP340 download section). It would be good to also have the ICA (AVAXP-006) and AFMS (600-00309-000) posted to the download section since these are part of the STC approval.
Simpson?
This page was generated in 0.171 seconds.
