  New Posts New Posts RSS Feed - Cooling Fan for IFD540??
mfb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mfb Quote  Post ReplyReply Direct Link To This Post Topic: Cooling Fan for IFD540??
    Posted: 20 Dec 2014 at 8:50pm
Is an external cooling fan required or recommended on an IFD540 installation?
My IFD540 will be installed at the top of the radio stack in a C-182P. There will be an audio panel above it, a KX165, Strikefinder, and a Century 2000 autopilot below it. Will that be too much heat?
The existing KNS80 (which is going away) has been running forever with no fan. But whoever installed it put in little ducts from fuselage air scoops directly into the radio stack. That doesn't seem like very good practice, unless your radios are rain proof.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2014 at 12:12am
Section 5.5 of the installation manual is titled "External Cooling".  It reads, in part:
Quote The IFD5XX does not require external cooling, however, additional cooling may prolong product life. A 5/8” diameter air fitting is provided in the rear of the IFD5XX mounting tray, if forced air cooling is installed.
IFD5XX installations in a tightly packed avionics stack should consider installing an electric avionics cooling fan. As a minimum, plan to leave space for clear intake and exhaust venting when able. If a fan is installed, ensure the intake air flow to the fan is not located near the exhaust of other fans or near other hot equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2014 at 8:36am
Yes, Section 5.5 is Avidyne's position.
I will note that I fly a C-182Q with a full stack, where from top to bottom, I have AMX240 Audio Panel, IFD540, IFD540, AXP340 Transponder, DFC90 Autopilot.
I have a cockpit switch to turn the ice box forced air cooling fan on/off and as it turns out, I never turn it on, even in the summer.   We have temperature readout diagnostics in maintenance mode and we have internal logging and flagging to look at unit temperature.   I haven't ever had a problem with unit overheating.   Some of our heat dissipation design is to pull unit heat out of the box via the front bezel.  That tends to make some folks  think that the box is (too) hot when in fact, this design pulls the heat away from the electronics components inside and it works well.
We also have Caution Alerting System (CAS) messages that will display on the IFD if it does hit high enough temperatures where forced cooling would be helpful.
PA20Pacer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2014 at 9:00am
Hi Steve-
On a similar topic, I will be installing my IFD540 next to an Aspen display, which has a similar projection of the bezel from the panel. Is there a minimum distance that I should maintain between the Aspen and the IFD540 to ensure that I do not block the cooling airflow from the vents in the bezel? My current plan has a distance of 3/16" between the two bezels. Thanks.
Brookeridge Airpark (LL22)
Downers Grove, IL
mfb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mfb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2014 at 10:50am
I did read the language in the installation manual. I'm sure it's Avidyne's official position, but it includes vague terms like "may" and "tightly packed." As an owner, I don't have enough experience to know if my installation is tightly packed or not.
Steve's airplane is very similar to mine, and he has a lot more stuff in the panel. So it seems I'm not very tightly packed. And he has a fan but doesn't use it. Very interesting.
But I'm still concerned about the "may prolong life" language. I know that heat and electronics don't go well together. Is the internal instrumentation good enough to tell me not only when the unit is really overheating, but just when it's warm enough to hurt its service life? Or maybe I should just install the fan anyway, as a $450 insurance policy. It's not much in the overall cost of the project.
My venerable KNS80 has lasted well over 25 years without any cooling. Is the IFD540 build quality as good as King's used to be in the "good old days?" I probably won't be flying another 25 years, but I'd still like this box to last for a while.
Thanks for your thoughts.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2014 at 12:20pm
Just FYI, again from the install manual:
Quote The metal bezel of the IFD5XX is intentionally designed to radiate heat away from the internal components and out of the unit.  This can have the effect of a bezel that may be warm to the touch.  This is considered normal.
I don't believe there are "cooling vents" in the bezel.  Sounds like it just gets warm and radiates/convects out into the cockpit.
Edited by MysticCobra - 21 Dec 2014 at 12:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2014 at 7:25pm
I told my installer to put in a fan.  Compared to the rest of the cost of your investment, its cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2014 at 8:00pm
I have the full stack in my Bonanza consisting of AMX240, IFD#1, IFD#2, AMX340. The front bezels are warm on the AMX, warmer on the IFDs, hot on the AMX. When I looked at the diag temps they were 10c less than the threshold on the hottest day of the summer and I don't have air conditioning. I do have some type of thin fan that sits along side the stack and draws heat away from the stack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2014 at 9:06am
The IFDs do have several internal fans that facilitate heat removal.  There are exhaust ports along the left and right sides of the chassis and the accompanying trays have cut outs aligned with those exhaust ports to facilitate venting.
In addition, the left and right sides of the front bezel do have intake louvers designed to draw ambient cockpit air into the unit.   While not required, if installation flexibility permits, the unit can benefit from these intake and exhaust ports remaining as clear as feasible.
Jrlumpp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrlumpp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2014 at 11:39pm
I called avidyne and a rep told me he didn't think a additional cooling fan would be needed in the NorthEast where I fly. He thought it might be more needed in the SouthWest region. I will leave it up to my installer.
This page was generated in 0.059 seconds.
