  New Posts New Posts RSS Feed - 2 Questions
2 Questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Topic: 2 Questions
    Posted: 17 Dec 2014 at 8:50pm
I made my first long term with the 540s today while enroute to the Bahamas from RI.   The units are even more incredible the more I get to use them.  I have a couple of questions that I have not been able to answer while looking through the manual.
1.  In the Air/Data Calculator page,  the unit will give the winds aloft direction and speed after entering in the needed info to calculate it.  Is there anywhere in the 540 where it will give you the headwind/tailwind component of the wind?
2. I noticed while flying my flight plan, that my #1 unit always put the next up VOR freq into the active position but my #2 unit put the freq into the standby position.  I imagine this must be a setting issue but I cannot seem to find where the setting is change the default.  Perhaps in a dual installation #1 defaults to active and #2 to standby?
3. I discovered one other use for the TOD chime on my flight.  ATC asked me to report 62 miles from my destination.  At the time, I was about 100 miles away flying GPS direct.  I wanted a reminder so I would not forget to give the position report and thought about creating a waypoint on my route which was 62 miles from the destination but thought it easier to set up a TOD warning.  I put an altitude 1000 feet lower than my present altitude at a distance 62 miles before my destination into the destination on the FPL page.  At a decent rate of 500 feet/min, I knew I would get the chime, 2 min before the fix.  Worked perfectly!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2014 at 9:06pm
#1 I have not found Headwind/Tailwind component, so I believe the answer is NO
#2 Yes, it is called Auto-VLOC Tuning in the user settings and if set to "On" it will tune and identify into the active NAV frequency the VOR.  Page 4-37 of the user's guide.
#3 I believe the ability to add markers like this in the unit has been requested before and I believe is in the feature request database.
Edited by Gring - 17 Dec 2014 at 9:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2014 at 10:02pm
Not 60 miles, not 65 miles, but 62 miles!  Never been asked to make a report like that in my short flying career.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pburger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 7:35am
I haven't flown a real cross-country flight with the 540 yet, but the calculator in my old jurassic G-brand GNC-300XL would give the headwind component when calculating winds aloft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 8:28am
Reference #1, we've added the HW component digital display to the Air Data  Calculator as part of Release 10.1 due out in the spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 8:56am
Yup, that was requested, in the post requesting a whole variety of cool direct-add FPL page user defined points.
Edited by oskrypuch - 18 Dec 2014 at 8:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 3:23pm
I'll have to play with the Auto-VLoc tuning again on my next flight.  I thought that was too obvious but both of my 540s were set to ON so I thought there had to be another explanation.
This page was generated in 0.095 seconds.
