  New Posts New Posts RSS Feed - GPS failure
GPS failure
 Post Reply Post Reply Page  <123
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2015 at 5:21pm
Page 4-46 of the Pilot Guide defines the possible GPS states.
If on the ground and the system has not acquired a GPS lock within 3 minutes, you will receive a yellow "GPS Fault - No Position" CAS message.  See page 6-5 of the Pilot Guide.
If in the air and GPS is lost, you will receive a yellow "GPS Fault - Dead Reckoning" CAS message.  See page 6-5 of the Pilot Guide.
Or, as you note, you can look at the AUX page, SYS-GPS Status for detailed satellite lock information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 2:21am
Thanks Steve. So a yellow GPS indication without active flight plan leg is fine as long as there is no CAS message.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 8:15am
Correct.
cajungene View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cajungene Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 4:35pm
I had multiple failures on 5/26/15. I've downloaded th logs and sent them to techsupport@avidyne.com. Is that sufficient or should I send them to a particular tech?
Gene
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2015 at 4:19pm
That email address is the best one to send logs to.
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 11:06am
Just curious, for the people that were having GPS problems before 10.1 - have those problems been resolved? Did 10.1 fix the GPS lock problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 11:20am
I have almost ten hours flying behind version 10.1 now, and not a single GPS problem.  That said, I only flew a few hours with version 10.0.3.0 and I never noticed a GPS problem then either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 1:02pm
I haven't had any recent GPS issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 1:10pm
Mine has been fine also.  No more GPS issues at all.
ksdoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksdoc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 9:59am
Nope, didn't fix it for mine.
After leaving the shop, 5 minutes into flight home the GPS signal failed again! I just returned from vacation and during both legs, the signal dropped once. It lasted a few seconds and then reacquired. I had to reset the Aspen back to GPSS and SV, otherwise no significant issues.
It has not had the same problem during initial startup as it did before, so there is a plus.
So, having installed the unit back in October, I have not had one flight where the unit did not fail at some point during the flight! And I'm on my third replacement unit.
Avidyne thinks they finally understand the problem and plan to send me a new 540 next week, so we'll see. I guess I'm one of the 'lucky ones'! :)
kansasdoc
VDH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VDH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 12:16pm
I have a serious problem with my IFD540 where it consistently takes a very long time to acquire satellites.  It takes between 10 and 30 minutes for the unit to acquire satellites and the unit reports a "GPS Fault. No Position".  During this time the transponder does not transmit an ADSB-out signal.  It also occasionally drops out for 30-60 secs while in cruise.
I recently had the latest software update but it made no difference to this issue.
I had my avionics shop download the logs a week ago and submit them to Avidyne.  The download took an excessively long time - like a couple of hours. Despite having had them for more than a week, my avionics shop has had no response despite following up multiple times.
Avidyne - what is going on???  The aircraft is essentially unairworthy (at least for IFR) with this fault.  It is unreasonable not to even have a response after this length of time.
Edited by AviSteve - 19 Sep 2023 at 1:19pm
Mooney 20J
Mount Beauty, Australia
AviBryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviBryan Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 12:33pm
Hi VDH,
I'm sorry you're seeing this issue. Have you reached out to Pilotsupport@avidyne.com or called our support line? I'm just trying to understand what you mean about not getting a reply in so long as this is the only post I see from you on this thread. My apologies if I'm overlooking the information but would you please email me at bkahl@avidyne.com with your contact information and Copy pilotsupport@avidyne.com. We will get you taken care of!
