  New Posts New Posts RSS Feed - suggested rephrasing
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: suggested rephrasing
    Posted: 22 Apr 2014 at 10:55pm
Suggested rephrasing ...
Original:
The only waypoints that do not permit vertical constraints are:
  Origin
  Destination, provided there is an approach loaded for it
  Missed Approach Point
  Altitude Terminated Legs
Suggested change:
  Origin
  Destination, if it has an approach selected
Edited by oskrypuch - 22 Apr 2014 at 10:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2014 at 3:40pm
Okay.  Done in Rev 00-F.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2014 at 8:47pm
Rog.
BobsV35B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobsV35B Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2014 at 11:06am
Good Morning Orest,
Are you suggesting that we who fly mostly VFR are not supposed to use the IFD540?
I have been flying for 68 years and have accumulated in the vicinity of 38,500 hours, but at least ninety percent of my current flying is VFR with NO flight plan filed. I want the capability of shooting a WAAS approach if it fits my fancy, but most of the time, I just start the engine and go fly.
When something pops up, the drill for me is to go direct to wherever I wish to enter into the IFR system and that will most commonly be some point close to where the approach will be initiated.
I am VERY interested in how to go direct to some segment of an approach easily and quickly without the need for loading a full flight plan first.
The KISS system works great for me. Please no not denigrate we VFR flyers!
Happy Skies,
Old Bob
Old Bob, Ancient Aviator
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2014 at 3:16pm
Old Bob,
I have no idea why you are saying that. Please explain.
Any kind of flying is GREAT, from Cubs at 500 ft AGL with the wind in your hair, to Jets in the flight levels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2014 at 3:59pm
I'll raise my hand here and say Bob, that was my comment in the operational no dups allowed thread, not Orest.
phkmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phkmn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2014 at 4:01pm
Bob, did you get an answer to your question, which appeared to be "How do I set an approach when no flight plan is filed?"?
If not, it appears that you need to at least input a destination, either via "Nearest" or type in a Direct To.  Once you have that, just select the desired approach and activate it.  You can then highlight the desired waypoint from which you want to initiate the approach and use the "Direct to" again.
PH
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobsV35B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2014 at 6:09pm
Good Afternoon PHKMN,
If you felt that I was asking a question, I am sorry I did not phrase my comment well.
I thought someone was saying that we who normally fly with no flight plan being filed were doing something wrong. <G>
In any case, I appreciate your concern.  I am confident I will be able to initiate a clearance when one is needed.
Thank you for your thought.
Happy Skies,
Old Bob
Now, if I can just get it installed before Oshkosh!
