  New Posts New Posts RSS Feed - integration with TAS600/605
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: integration with TAS600/605
    Posted: 09 Apr 2014 at 4:10pm
The GNS products have a traffic page, that also provides some menu controls that allow you to set the few variable parameters for active traffic units.
The IFDs do not have a traffic page, and it appears that you can only change the displayed range in the thumbnail. Do you have to get the add-on control head in order to change things like enroute vs approach, and so on? If so, that seems to be an oversight.
What am I missing?
Edited by oskrypuch - 09 Apr 2014 at 4:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 4:34pm
I think you're speaking about the traffic "shield" or filter (Below, Normal, Above, Unrestricted).  If so, check out page 3-26 and 3-27 of the Pilot Guide and see if that covers what you're seeking.
You can change the shield/filter by pressing the LSK adjacent to the traffic thumbnail.  Tapping the thumbnail is the method to range change the thumbnail.  Pressing the lower 1/3 or the adjacent LSK is how you manually change the shield/filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 5:06pm
OK, doing so appears to just turn the traffic ON/OFF on the simulator. The "NORMAL" indicator remains.
Would that actually change to indicate, unrestricted, above, below (approach), normal etc. in the real unit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 5:07pm
Yes, I use it on every flight in the real unit.  I'll check out the simulator and see why it turns it on/off instead of changing the shield.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 5:40pm
Very good. I'm just musing getting the TAS unit.
I understand that the 605 has ADS-B enhancement priced into the purchase already (although not available until release), which seems a good deal, for about the same price as teh 600 + the ADS-B "A" enhancement later.
Besides extra range and ceiling, the 605 also has heading adjustment, for smoother on map panning, yes?
Edited by oskrypuch - 09 Apr 2014 at 5:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2014 at 1:36pm
<bump>
Also, the GNS have the ability to set/arm an approach mode when using the L3 or  Ryan, and I presume an Avidyne TAS. This in part includes having to set a ground elevation. This is different from just a traffic filter, above, below, etc.
As the IFD does not have a traffic page, is there a menu setting for this somewhere when such a device is attached, or is the approach mode only accessible when using the TAS6xx control head?
Edited by oskrypuch - 16 Apr 2014 at 1:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2014 at 6:24pm
Ahhh, beats me.  I'll have to look into both on Thursday.
