  New Posts New Posts RSS Feed - DFC90 STC for Bonanzas Granted today
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Topic: DFC90 STC for Bonanzas Granted today
    Posted: 10 May 2013 at 12:32pm
Will post more details tonight when I return from a XC but we officially have TSO/STC approval for the Avidyne DFC90 in Bonanzas (33, 35, 36 models)
Post Options Post Options   Thanks (1) Thanks(1)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2013 at 8:07am
The table below lists the Bonanza models covered by this STC.  Both 14V and 28V aircraft are covered.
The DFC90 is plug and play with the STec 55X (meaning just the control head needs to be replaced and all other elements can remain untouched).  It is also approved to replace the STec 30/50/55/60-2/65  but obviously the control head is not just plug-and-play in that case.
The install also requires the presence of an Aspen PFD (EFD1000) with v2.6 or later software.
Wiring in the flap position switch is optional.  Doing so adds the "Flap Overspeed" aural alert and improves the accuracy of the full-time Envelope Alerting underspeed alert (stall speed changes with flap position).   The STC allows for installations with and without the flap wiring.
Model
GW
CG
Ctrl
Vne
Vfe
H35
2900
+82.1-84.7
Flaps: 30° Down
Aileron: 20° Up/ 20° Down
Elevator: 22.5° Up/ 17.5° Down
182 Knots
104 Knots
J35
2900
+82.1-84.7
Flaps: 30° Down
195 Knots
104 Knots
K35/M35
2950
+82.1-84.7
Flaps: 30° Down
Elevator: 22.5° Up/ 19° Down
195 Knots
104 Knots
35-33
2900
+82.1-85.7
Flaps: 30° Down
Elevator: 25° Up/ 15° Down
195 Knots
104 Knots
N35
3125
+82.1-85.7
Flaps: 30° Down
195 Knots
104 Knots
35-A33
3000
+82.1-86.7
Flaps: 30°
195 Knots
104 Knots
35-B33
3000
+82.1-86.7
Flaps: Down 30°
195 Knots
104 Knots
P35
3125
+82.1-85.7
Flaps: 30°
Elevator: 22.5° Up/ Down 19°
195 Knots
104 Knots
S35
3300
+82.1-84.7
Flaps: 30°
Elevator Tab: 22.5° Up/ 19° Down
195 Knots
113 Knots
35-C33/E33/
F33
3050
+81.5-86.7
Flaps: 30°
195 Knots
104 Knots/ 113 Knots with Item 403(s) installed
G33
3300
+81.3-86.7
Flaps: 30°
195 Knots
122 Knots
V35/V35A/
V35B
3400
+82.1-84.4
Flaps: 30° Down
197 Knots
123 Knots
35-C33A/ E33A/E33C
3300
+82.1-86.7
Flaps: 30° Down
132 Knots
113 Knots
36/A36
3600 (1) or 3650 (2)
+81.0-87.7(1)
or
+81.0-87.7(2)
or
+74.0-87.7 if 3100 lbs or less
Flaps: 30° Down
Elevator: (23° Up/ 20° Down)(1)
Elevator: (25° Up/ 20° Down)(2)
204 Knots(1)
or
205 Knots(2)
123 Knots(1)
or
124 Knots(2)
F33A/F33C (Utility)
3400
+82.1-86.7
Flaps: 30° Down
197 Knots
123 Knots
A36TC
3650 (1)
+81.0-87.7(2)
or
Flaps: 30° Down
203 Knots
123 Knots
twalterhome3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twalterhome3 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2013 at 4:30pm
How much of a priority is it for Avidyne to get the servos done so we can put DFC90s into bonanzas with King KFC200s ?
Without committing you to an actual time estimate, at least can you say if this is now a high priority task for you?
Tim
