  New Posts New Posts RSS Feed - Loading future data bases
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Topic: Loading future data bases
    Posted: 13 Sep 2023 at 8:26am
I can imagine how difficult two database support would be to implement if the AviOS wasn't designed that way from the start. Just a bit of a shame that Avidyne didn't take on that element of the 20 year old gns480/cnx80 when they decided to design a new FMS-type gps/nav/com.
Edited by chflyer - 13 Sep 2023 at 8:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 8:13am
The only question in your post was:  "If a future dated database is installed, does it become active upon install or is that data not available until the "go-live" date? "
The answer to that question was already explicitly stated:  "You can only have 1 set of databases installed at a time. If you install databases before their effective date, they'll overwrite the active set."
So, to make it expliciter, the answer to your question is, "It becomes active upon install."
Edited by MysticCobra - 13 Sep 2023 at 8:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 7:10am
The answer was implied but I will make it explicit.
No, the future database is not valid and cannot be legally used before its issue date.
yce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yce Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 6:28am
actually- it doesn’t.
The database is present on the unit. Does the software, seeing data tagged with a future date, use that data? If nav data is good upon receipt (which is what I’ve always heard) then the future date warning is just an annoyance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2023 at 12:12am
Re-read the post above yours.  It answers your question.
yce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yce Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 9:55am
My understanding is that nav data is good "upon receipt" so that data should be good.
This is one thing I miss from my CNX-80- the ability to load more than one database and have it automatically switch to the newer one when necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2023 at 2:38pm
You can only have 1 set of databases installed at a time. If you install databases before their effective date, they'll overwrite the active set. Best you can do is to preload the databases onto a USB stick before the effective date, then install them when you need them.
swyloge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swyloge Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2023 at 12:39pm
Is it possible to load future NavData and Obstacles data bases into the IFDs? If so, then how do I install them when they become effective?
Swyloge
