  New Posts New Posts RSS Feed - IFD + G5 + GFC500 + VNAV
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Topic: IFD + G5 + GFC500 + VNAV
    Posted: 23 Aug 2023 at 11:13am
With the release of 10.3.1.2 my installation (Dual IFD540s, Dual G5s, GFC500 autopilot) now shows some automation between the boxes for VNAV.  Prior to this release, the VNAV button didn't light up, nor was it annunciated on the G5.
With an all Garmin system there are 4 things that must be met to have VNAV work
  1. VNAV angle set
  2. Altitude constraint set on a waypoint
  3. Altitude preselect set to the lowest altitude in a descent, but no lower than the FAF altitude
  4. VNAV enabled on the GFC500 mode controller
With the Avidyne, I have all 4 things
  1. VNAV angle is set in the setup
  3. Altitude preselect set properly
  4. VNAV enabled on the GFC500 mode controller and VNAV annunciated in white (armed) on the G5 autopilot annunciator
When VNAV is met, the Avidyne CAS message alerts, the TOD tone is heard, and the VNAV carrot is displayed on the G5.  The only thing that doesn't happen is the mode never changes to VNAV mode from ALT hold mode.
Is Avidyne working on tighter integration with the Garmin autopilot and PFD platforms?  It seems like we are almost there.
Edited by Gring - 23 Aug 2023 at 3:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2023 at 8:03am
This sounds like an Arinc label that the GAD29B/G5 is expecting that the IFD isn't sending. Possibly a G* secret?
By VNAV carrot, do you mean this?
If so, I suspect that the only option is to revert to ROL/PIT mode and manually fly the FD..... but then perhaps the armed VNAV disappears?
BTW, I assume that both your IFDs are connected via the GAD29B to the 2xG5 only (i.e you don't have any other CDI in the panel). Correct?
Edited by chflyer - 24 Aug 2023 at 8:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2023 at 8:39am
Correct, I see the VNAV indicator on the G5, and it works correctly with the VSR I've setup in the iFD.  In other words, I can manually fly the VNAV indicator on the G5 ADI and HSI - that works correctly from TOD to the crossing altitude in the FMS flight plan waypoint.
I have an L3 ESI500 backup connected to my IFD#1 for GPS and #2 for VOR and a GI106 connected to my IFD #2.  So, yea, lots of connections between all the boxes in the airplane.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2023 at 8:57am
So you can select all nav sources on the G5s then? My understanding is that having a CDI on the same nav unit as a G5 is not allowed. There is a comment to this effect in the G5 IM (note 6 to Fig 5-12). Are you experimental and therefore have more freedom to not follow the STC?
IOW, can you display GPS1/GPS2 on both the G5 and L3 for GPS and VLOC1/VLOC2 on both the G5 and CI106 for VOR/ILS/LOC?
Edited by chflyer - 24 Aug 2023 at 9:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2023 at 2:35pm
This is a certified installation in a Beechcraft Bonanza.  I can display GPS1, GPS2, VLOC1, VLOC2 on my G5s.  The GI106 can only display VLOC2 due to your mentioned limitation.  My L3 ESI500 can display GPS1, VLOC2 on it.
Edited by Gring - 24 Aug 2023 at 2:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 4:05pm
Here is a better picture of the IFD VNAV displayed on the G5
Edited by Gring - 27 Aug 2023 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 7:33pm
Thanks for confirming your display config. That will be useful in discussion with my avionics shop. Thanks too for posting the photo …. looks great and now looking forward to having a similar setup in a few months. The main thing missing from my SN3500 (to be replaced with a G5 HSI) will be the name of the current GPS wpt, which I assume is the distance shown on the HSI above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 8:12pm
Correct, the G5s are a nice simple PFD/HSI setup to replace mechanical gauges for those who want to retain a 6 pack.  In my case, although the G3X isn't on the IFD STC and vice versa, it still connects through the GAD 29B, I just didn't want to take a risk of it not integrating properly.
There are things I miss and the G5 could be larger, but all in, it is a good option.  The redundancy is good, I can use the GFC500 with either the ADI or the HSI in reversionary mode as an ADI.  I can use GPS1, GPS2, VLOC1, VLOC2, so lots of options if something failed.  I had sent my IFD #1 out for repair and was still able to fly the airplane with my #2, although there were some minor things that didn't work like my TAWS annunciator since it was tied only to my #1.
I would have liked to have an all Avidyne panel including the autopilot, but not quite yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 8:43pm
As you might expect, Garmin isn't particularly keen on sharing details...
Victor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 12:55am
The G3X integrates nicely with the IFDs. It is full integration between the GFC500 and IFD that is the issue, although not insurmountable, particularly since Avidyne joined the VNAV party.
I have the following setup in my Mooney; G3X, G5, GFC500, IFD540 and an IFD440. The VDI always displays on both the G3X and G5 together with the auto loaded altitude constraint when a descent is imminent.
When the VDI indication is at the point of descent, I need to manually select VS and use the vertical wheel on the GFC500 to control the descent rate, which is close enough to the VSR displayed on the IFD.
I understand the GFC500 and GTN combo does all this for you, however the GFC500 and IFD combo operation is not onerous at all.
I assume what I have described is not all that different to your setup.
BTW; I understand that Avidyne have approved the experimental version of the G3X and IFD integration. Perhaps AviSteve can confirm this.
Edited by Victor - 28 Jan 2024 at 12:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 8:28am
Victor, thanks for your clarification on the G3X integration which was what I suspected.  I've been an early adopter of Avidyne as well as a CFI/II specializing in teaching avionics, so I regularly fly with clients/students with the Garmin platform.  It is not without it's challenges, especially with VNAV which can get you in a lot of trouble if not used and monitored correctly.
At the time of my installation, I had failing King products and had to make some quick decisions and Avidyne had not yet shown the G3X compatibility with the IFDs.  I took the safe route at the time.
Steve, it's too bad because it seems like you have almost all the pieces for VNAV with the only part missing is the command to descent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 5:05am
2xG5, GFC500, IFD540/440 combo installation just being signed off and almost ready to go fly this thing.
Looking at your last photo, Geoffrey, it looks like you've selected VNAV on the GMC507 which populates the VNAV armed and vertical guidance fields, but you don't get the vertical speed VS annunciation based on IFD input so VNAV never never activates to VNV, is that correct? Is the VS button on the GMC507 unresponsive? To fly the VNAV guidance manually as you mention, do you just turn off the AP and keep the FD in ROL/PIT mode (AP is still shown as active in the last photo)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2024 at 10:19pm
All vertical modes work as expected, but VNAV only annunciates as armed.  It never activates.  The VS button works fine and you can use the mode controller to set it.
If I’m using the autopilot in a lateral mode like NAV or APR and I reach my TOD, I simply switch from ALT hold mode to VS mode and down I go until I hit my desired altitude.
Hopefully I understood your question correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2024 at 7:31am
I think you've understood my question correctly. In the photo above, my understanding is that once you switch from ALT 3000 to VS -500 (or similar) the autopilot continues to fly but using the selected VS rather than holding altitude. Does it keep you on the desired vertical path (V-indicator next to airspeed in the middle)? Or is it just tracking and you need to adjust VS and/or power to stay on the desired vertical path?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2024 at 12:12pm
It just works like an old school autopilot. The G5 displays the glide path you need based on the VSR setup in the IFD. You track that by adjusting the VS mode and dial. Adjust as required. I have the VSR field as one of my datablocks so that helps quite a bit.
