  New Posts New Posts RSS Feed - Visual approaches not available at ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Visual approaches not available at ...
    Posted: 06 May 2023 at 9:36pm
At airports without IFR approaches, there appears to be no way to select a visual approach. Ironically, that is the very type of airport at which you'd likely want to select a visual approach. Am I missing something?
Sure, you can OBS on the airport as before, but not quite as good. Is it because the runways are not surveyed?
Edited by oskrypuch - 06 May 2023 at 10:01pm
ricardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 12:41am
I think thats why.
Don’t have a link for the source . but i remember hearing in a some presentation that visual approaches require certain GPS data for the runway.
Edited by ricardo - 07 May 2023 at 12:42am
LarryPetro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 12:43pm
Eagle Crest airport, DE25, doesn't have an instrument procedure, but AviOS 10.3 does present visual approaches to RWY 14 and RWY 32.
Edited by LarryPetro - 07 May 2023 at 12:45pm
Melohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 3:15pm
INFO Airport Runways tab. If there is a Lat/Lon for each end of the runway, Visual approaches will be available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 10:48pm
