IFDs with GFC500 - Again! |
tmbm50
Newbie Joined: 24 Apr 2023 Location: PA Status: Offline Points: 17 |
Posted: 25 Apr 2023 at 8:55am |
Hi All - sorry for another thread on the GFC500 and IFD interop. Searching shows so many questions and threads but they all seem to derail on side topics or confusing Garmins VNAV feature with other concepts.
I have IFD550/440s in my new plane and planning a new set of GI275s and GFC500. So far I like the IFD so trying really hard to not go the GTN route. So perhaps someone can provide some quick clarity for me to confirm the following. 1. Garmin VNAV will not work. And by VNAV, I mean the IFD will not command the AP to descend when it hits TOD for a waypoint. I'll have to twist the Alt knob when the IFD tells me too. No big deal. This is unrelated to approach mode. 2. IFD when on an ILS approach will capture the GS and enable a coupled approach and command the AP vertically....ie it would fly it onto the runway if I wanted too. 3. IFD when on a RNAV approach (assuming is LNAV/VNAN) will capture the GS and enable a coupled RNAV approach and command the AP vertically to minimums. 4. On a missed approach, the Go round button will command pitch up and wings levels. But the IFD will not automatically load the missed approach? Are all those assumptions correct? Edited by tmbm50 - 25 Apr 2023 at 9:06am |
Craig767
All except last part of 4. If you have Baro Alt into IFD will automatically load miss. All you have to do is hit NAV after 400ft and it will fly coupled missed app.
tmbm50
Thanks! Thats good to know on number 4.
I know its always touchy for Avidyne to comment on other vendors but it would be a useful sales tool for Avidyne to document what is possible and what is not. The amount of misinformation and push to go all Garmin from dealers is certainly driving alot to Garmins bottom-line. I'm scheduled for upgrades at the end of May so should have first hand report soon.
ricardo
Senior Member Joined: 17 Jan 2022 Location: Seattle, wa Status: Offline Points: 133 |
i just had a GFC500 added to my airplane that has a IFD440 as nav1 .. works like a charm.
(I’m using dual G5’s so similar to your setup) as was already stated .. the setup will fly a coupled missed. one thing that came up in training is that with the IFD you need to wait until you have vertical guidance before hitting APR on the GFC500 to arm the GP or GS. (not sure if its different on garmin, but my instructor was adamant i could hit APR once i was cleared for the approach, which often occurs before vertical guidance shows up). |
The IFD loads the missed approach as part of the procedure, and will always have the missed approach leg shown after the final approach leg. Normally, the final approach leg ends and the missed approach leg begins at the runway threshold (waypoint). When configured for an automatic switch to missed approach, the IFD will increment from final approach leg to the missed approach leg at the MAP, so if going missed at DA the a/p should track the final approach up to the MAP when the IFD sequences to the missed leg for guidance. The MAP is also the point at which VLOC switches back to GPS if on a VHF approach.
Just to add, at the missed approach point, if you have Baro (which you will with the GI275), you can push the TOGA button and it will pitch up, then as you are climbing, you can press the NAV button to follow the missed approach.
Second, you can press the APR button any time, you don't need to wait until you have vertical guidance. You could hit APR as soon as you level off in cruise if you wanted to.
