Forum Home Forum Home > Company News > Company News
  New Posts New Posts RSS Feed - Submit your suggestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Topic: Submit your suggestions
    Posted: 23 Feb 2023 at 4:07pm
Avidyne has implemented a new mechanism for submitting product suggestions.  On the main website page, click on "Contact", then "Share your thoughts".  Fill out the form and give us as much information as you can about the suggested product improvement.
As of 2/23/2023, this link will take you directly to that page.
You're still welcome to post suggestions here, but using the new mechanism will help us to keep them organized.  It will also help to prevent us from thinking "I know there was a suggestion about xyz, but I can't find it now..."
Gring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 6:57pm
I submitted two suggestions
One is the addition of a switch tanks CAS message based on gallons burned.
The other is to move the new W&B calculator to the end of the list and keep the Fuel/Trip/Air Data calculators at the top since they are used most often during flight.
Melohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 6:36pm
My suggestion is to implement a Bluetooth Client in the same way the Wireless client works in 10.3. That way we could get the same dynamic update behavior from ForeFlight that Garmin devices get, and “enhanced” traffic from my GTX 345 would be available.
This page was generated in 0.156 seconds.
