  New Posts New Posts RSS Feed - IFD trainer 10.3
IFD trainer 10.3
buz914 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote buz914 Quote  Post ReplyReply Direct Link To This Post Topic: IFD trainer 10.3
    Posted: 19 Feb 2023 at 8:49pm
When I use the trainer it won’t gain altitude after activating a flight plan. I only have a speed adjustment to play with?
I’m sure I’m doing something wrong?
ricardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 9:22pm
look at the autopilot settings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote buz914 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 10:00pm
So I guess I can start in autopilot mode and then switch to follow flight plan mode. Seems like follow flight plan mode should let you pick a starting cruise altitude otherwise it skims the ground at random low altitudes.
afassas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote afassas Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 11:58pm
To select altitudes in Follow Flight Plan mode, you must enter an altitude restraint on the active waypoint segment.  This would be done from the FMS - FPL page and tab.
Alex Fassas
Avidyne IFD-540
Lynx NGT-9000+
Beech A36
KRGA
This page was generated in 0.025 seconds.
