  New Posts New Posts RSS Feed - 10.3 issues seen
10.3 issues seen
ansond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ansond Quote  Post ReplyReply Direct Link To This Post Topic: 10.3 issues seen
    Posted: 30 Sep 2022 at 11:49pm
Hi:
Just FYI, after the 10.3.0.2 update (which went flawlessly...), I have discovered the following issues:
1). (previously reported)  COM freqs don't persist across reboots
2). If I try to enter a direct-to airport, my other IFD440 will pop up the keyboard as expected... I can then try to type the icao id of the airport which works fine... however, the "Activate KXYZ" simply comes and immediately goes away... My current workaround is to use the BT keyboard which allows the "Activate KXYZ" to persist until I select it
3). I cannot seem to edit the "cross"/"at"/"wxyz ft" section in the FMS via the latest IFD100 on my iPad... I have no problems editing it on either IFD-440 though.
4). I have seen cases where on one of my IFD-440's, I can "direct-to KXYZ" but that my other IFD-440's FMS will still show the previous "direct-to" that was entered.
Happy to discuss these with tech support if that'd be useful.
Doug
N208LG
Edited by ansond - 30 Sep 2022 at 11:49pm
