  New Posts New Posts RSS Feed - IFD540 Certification Status
 Post Reply Post Reply Page  <1234 12>
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2013 at 7:38pm
Quote  That being said, they did identify two specific areas that likely would produce a cert problem.  I think they were right and we will address both issues prior
What kind of thing(s) was that, if you can say?
Edited by oskrypuch - 02 May 2013 at 7:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2013 at 7:54pm
Sure.
Issue #1: When we are panning the map to a location not co-located with the ownship position, we effectively froze the map so the pilot can see a steady and non-moving map when reaching that pan position. If however, the aircraft heading was changing while in the panned state, the heading box at the top of the temporarily frozen map would not update.   The change will be to always keep the heading box at the top of the map representative of actual aircraft heading.  There are some subtle nuances to that summary but close enough to get the idea.
Issue #2:  The IFD540 has Forward Looking Terrain Alerting (FLTA) as part of the baseline product.  This is a subset of certified TAWS and will alert the pilot via a message and an aural alert if it projects an imminent impact with terrain (approximately 60 and 30 seconds from projected impact).  It is suppressed around airfields or if the pilot manually toggles it off.  We annunciate the inhibit state but that wasn't a permanent display of the inhibit state.  The FAA noted that may be a cert issue so we intend to make that a permanent display when it is inhibited (in other words, no pilot action is required to display it but conversely, if the state is active, then the annunciation of it can not be removed).
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2013 at 10:28pm
Interesting, thanks, appreciate the insight. Fine details, but they could be issues.
Victor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 5:39am
I can't thank you enough for keeping us in the loop the way you have been.  To get on here the same day you flew with the FAA and keep us advised of the result is so very much appreciated.
Victor
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 1:34pm
Steve, I think you will avoid issues down the road (hazardous misleading data) if you just remove the heading all together when you pan the map.  Then once you leave the pan mode and the ship's solution is centered on the display, put it back.  I'm assuming the CDI still indicates cross track error in pan mode and that’s what the pilot should be flying anyway.  Everything else is situational awareness.
Just my opinion
Edited by tony - 03 May 2013 at 8:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 8:22pm
(IFD540 Status Update - 17 May 2013):
Flew the IFD540 with the FAA again this week (Thursday).  I would characterize the flight as also going well to very well.   This was the second familiarization the FAA has had with the unit and they ran through the intended full MPSUE flight profile and evaluation test events in our test 182 equipped with dual IFD540s.   The going-in objective of the flight was for the local FAA to dry run the MPSUE flight profile and tweak the run cards as required in support of the full MPSUE that starts in two weeks.   But, during post-flight, the FAA pilot decided he's seen enough of the system and will consider that his for-credit MPSUE flight evaluation.  He had a number of observations but no CIs (Certification Issues), PCIs (Potential Certification Issues) or RSEs (Recommended System Enhancements) which was great news.
As always happens with these things, the FAA has made some meaningful changes to the way they intend to run the MPSUE.   They have added several more (4) pilots to the evaluation team and their availability schedules are such that we actually start the MPSUE next week (technically this week since the Thursday flight will count) and run through the end of the week of 3 June, expecting the last flight to be on/about 7 June.
Of course, the more exposure the system has to evaluation pilots the greater the risk but we feel very confident going into this - we're ready.
AzAv8r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AzAv8r Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 8:26pm
Fabulous!  Thanks for the update.
Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2013 at 8:55pm
Is the MPSUE tests you speak of, where you give the platform over to the FAA and they operate it by themselves without Avidyne involvement?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2013 at 9:00am
For the MPSUE, the typical protocol is that the FAA evaluator pilot flies in left seat as the flying pilot, the Avidyne pilot sits in the right seat and serves as PIC but does not operate the system, fly the airplane or talk on the radio unless needed to for safety or asked to by the FAA, and a FAA Flight Test Engineer sits in the back seat and directs the run cards and records the FAA evaluator pilot comments and takes other notes.
We then debrief the flight afterwards and the FAA spends 1-3 weeks compiling all the FAA notes and the publishes an official FAA position on their findings.  They score each finding using a scale:
CI - Certification Issue;
PCI - Potential Certification Issue;
RSE - Recommended System Enhancement
Comment/Note/Observation - Self evident
Then the negotiation begins and we'll formally respond in writing as to the company position.  The general rule is that all CIs must be resolved before certification and PCIs are usually in the same boat while the rest are all negotiated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 6:08am
So if I'm reading this right, am I correct to assume that all the software qualification tests have been completed in the lab, and the last formal testing will be completed in about a month?  Have all the hardware qualification issues resolved?
Edited by tony - 21 May 2013 at 6:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 10:00am
No, I wish that were a correct read but it's not quite right.
We try to time the MPSUE to happen when a number of factors are right.  The principal considerations are:
1.  The system is representative of the final product such that all evaluations are against the design we intend to certify;
2.  The system is not so close to certification that any changes induced by the FAA evaluation would have significant and difficult to deal with schedule implications;
3.  The FAA evaluator pilots schedules permit the time.
We hit #1 a few weeks ago but couldn't schedule #3 until now.   For better or worse, we don't think we've added too much risk to #2.
We won't even consider starting the formal software testing until the look & feel and usability evaluations by the FAA are complete and closed out.    This is done because the software testing is so time consuming - dozens of engineers running tests almost around the clock for weeks and weeks.
We also are going to go back into formal hardware testing starting in about a week or so.   All the hardware and environmental testing we've been conducting for months has led to a number of good design updates/improvements and the last of those redesigned hardware components arrive in a few days.   We're looking at the last few months of hardware testing as terrific risk mitigation and design improvement and formal testing dress rehearsals and now go into the retest phase with high confidence.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2013 at 6:25pm
Steve, Thank you.  I have a pretty good idea now where you are.  I'm going to guess there are about 250 KSLOC in your image.  For the formal software testing are most of the tests manual?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 9:34am
Our SLOC count is actually 4-5 times that size.  We've got approximately 1.2 MSLOC which is clearly a daunting task.
On the good news front, about 450 KSLOC is the OS which comes as a Reusable Software Certification (RSC) package which means we don't have to review it or write/run tests for it - that has already been done.
Of the remaining 680K of Application flight code, about half is unchanged legacy code from R9 so the previous code reviews and test generation are complete and we can take cert credit for it.
Of the now remaining 340K of "new" code, about 1/3 is Level D which obviates the need for DO-178 style code review.
That leaves us with approximately 220K SLOC that need code review and test generation/running.  We started on that about 6 months ago and have been sliding more and more engineers to those tasks as they complete their pure development tasks.
As for the tests, a great deal are automatic in that once you write and dry run and review them, they can be automatically run and the test results are auto compiled.  There are still a lot of tests that are more manual than automatic due to the nature of setting up a specific configuration of avionics and having to verify visual behavior on the display.  For example, needing to see a flight plan leg turn magenta when it becomes the active leg is still a manual exercise for us.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 4:51pm
I'm fascinated with all the detail we're seeing here, and it helps with the wait.  ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 8:58pm
Steve,  thank you for the transparency.  Yes it's much clearer now.  From your response you must be using the OS from the guys in FL.  Its a stable product and we always have gotten great support from them.  I am impressed with the size of your OFP.  Please don't run out of room......
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 9:42pm
We're using the identical OS we use in R9 - it's called LynxOS-178 and is provided by Linuxworks with the RSC.  I know that at least Rockwell Collins and Avidyne use it in our avionics applications.
We also layer on top of that an ARINC653 partitioned architecture that essentially creates brick walls between the virtual machines running code at different design assurance levels (DAL).  In other words, a Level D application (e.g. Checklist) can not adversely affect a higher Level C (e.g FMS) or Level B (LPV guidance/deviation) application.  Each DAL runs in its own virtual machine - we segment the processor into several semi-autonomous virtual processors.   It's a pretty neat, sophisticated and highly effective architecture for this type of rigorous aviation application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2013 at 5:03pm
(IFD540 Status Update - 29 May 2013):
We're hot and heavy in the midst of the MPSUE.  We've put 6 FAA reps through ground training, ground eval and flight eval so far with about 5 or 6 more still to go.    We don't have any results yet - will make a post when we have something interesting to talk about on this front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2013 at 7:42am
(IFD540 Status Update - 4 June 2013):
Still in the middle of IFD540 MPSUE and it just got extended.  Due to scheduling challenges on the part of the FAA, we are now scheduled to conclude FAA flights on Friday 14 June.
On a side note, we are showing the FAA the IFD440 at the same time so we can hopefully avoid any new human factors/system usability evaluation with that product.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2013 at 9:01am
Well, not a biggie.
jperryfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jperryfly Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 2:09pm
Ref your comment on the 440 on 04Jun.
Does that change the target date for the 440?  I would just like to get a jump on selling my 430W so I can pay for the 440.
John in Fl
John Perry
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 6:31pm
Hi John,
Reference your question about IFD440 timing, we don't know but we hope so.   We'll be able to give a pretty good heads up on 440 cert when we're within 2-3 months of it's expected cert.  Might be wise to wait until then just in case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2013 at 3:57pm
I hate to be a nag, but did this complete?
Edited by tony - 17 Jun 2013 at 3:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2013 at 4:27pm
Boy, what a NAG!
Edited by oskrypuch - 17 Jun 2013 at 4:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2013 at 8:10pm
It wasn't but it is now.   The FAA had to weather cancel last week and rescheduled the two make-up flights today.
I am pleased to declare the MPSUE is now complete - at least all the FAA evaluation flights.  It took almost 5 weeks instead of the 1 they had intended - all due to FAA availability and weather challenges.
The next phase is to wait until they publish their Issues List.  I fear we'll have to wait another painful duration for that to get into our hands since the principal FAA rep that is responsible for creating and issuing the list is about to head out on vacation and he's unable/unwilling to delegate that list creation to anyone else.
In the meantime, we'll keep plugging away on the certification artifacts. We'll focus on the ones least likely to be affected by any FAA input from the MPSUE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2013 at 11:33pm
Well, maybe he'll be in a really good mood when he returns, and give you a Gold Star.
Edited by oskrypuch - 18 Jun 2013 at 9:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 5:36am
Did he indicate how long he will be absent?
Victor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 7:50am
The FAA rep responsible for the Issues List is busy with other applicants this week and is out all week next week.  He returns on 1 July.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 3:14pm
Did we get the redesigned hardware through environmemtal qual yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 6:45pm
Not quite.  I think we're 2-3 weeks away from being done.  We decided to re-run a number of tests with the new display glass.  No show stoppers so far and none anticipated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2013 at 8:06pm
after you receive your stc, how long will you allow the pilots program to run before you ship to the rest of us?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 11:29am
Pilot program should run between 3 weeks (enough time to determine if all is going swimmingly well) and 5 weeks (enough time if some installs are slow out of the gate or if feedback is slow to come in).
Based on how that pilot program goes, we'd either open up full-rate shipping at that point or fix any entry-to-service issue that was discovered during the pilot program.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 7:53pm
Well, I'm standing by. I'm ready to get going right away, on that new baby
Edited by oskrypuch - 29 Jun 2013 at 9:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 9:08pm
Do these developments bear any relation to the IFD 440 vert?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 10:15am
With respect to David's question about 440 cert, the short answer is "yes".   The tougher answer is in providing substantiating detail.
We still expect the 440 to be a "fast follow" cert behind the 540.  That may mean 2 months, that may mean 6 months.   We're flying 440s at the same time as the 540 in our test aircraft and we showed the FAA during the recent 540 human factors evaluation (MPSUE) that it's the "same, only smaller" version of the 540 so any considerations they have on the 440 *should* be resolved by any thing we do in the 540.
That being said, whenever we hit a resource crunch or an attention needing effort, the 540 will always win out over the 440.    That's an important statement in order to resist the temptation to cert both at the same time.  We don't want to accept the potential of delaying 540 by pulling in the 440.  We do ask ourselves nearly every day something like "will doing that with the 440 delay the 540 time to market by even a day and if so, is it really, really worth it?"  It's rare to hear a "yes" to that question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 2:18pm
Makes sense, Steve.
Maybe they will hand you an unsolicited "gift"...
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 5:15pm
so what is the expectation for the 540.August or Octobre?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 8:50am
Definitely not August for IFD540 Cert.  Instead of providing a date, I'll say that we have a few major milestones to get through before we can spike the ball.  You should consider measuring us against these remaining milestones to get a sense of the higher and higher confidence date.  Those remaining big milestones are:
1.  Receive, and react accordingly to, the FAA-generated MPSUE assessment of the unit.  This will likely drive some code changes but we won't know the magnitude until we get the official list from the FAA;
2.  Achieve 100% DO-178B Code Complete status.   This is well beyond "feature complete".  DO-178B "Code Complete" means we've finished all the code review and requirement tracing of the code per the FAA-recognized software standard.   We can't finish this until we know the code is done changing.  Note that we're done with all the changes on our end, we're just reacting now to any mandated changes;
3.  Officially declare DO-160 Hardware Qual testing to be complete;
4.  Achieve "Red Label" status on the combined hardware/software system.  This means that all formal for-credit software and hardware testing have been completed.  In other words, this is a submittable-for-cert system;
5.  Complete official company "for-credit" flight testing of the final submittable system;
6.  Complete FAA TIA (Type Inspection Authorization) testing.  This is the FAA's final exam of the complete system before they sign off on cert.
7.  Make our final submissions to the FAA of 100% of the certification artifacts.
We do consider this to be end-game of the program.  Some of those activities typically last only a matter of a few days (e.g. 5, 6, 7) and some take several weeks to get through (e.g. 2, 4).
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 12:36pm
Can I save on freight and just have Santa bring and install it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 12:59pm
Gosh, I sure hope so.   I might even come down and hand-deliver it......
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 5:44pm
dear Steve
I do appreciate your candor in the matter. It however does seem that everytime new .. or unannounced ... issues come up ..
I seriously hope and count on Avidyne delivering this year .. and have it certified by october.
It is about time that we start concentrating on the real important stuff ... like getting the MLX working on it..
Other than that I truly look forward to getting rid of the Garmins and getting a much more intuitive system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 7:09pm
Understood.
jkturner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkturner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2013 at 9:03pm
Are we seriously looking at October as the likely date for certification?  i was told when i purchased that the unit should be certified by June, I know that you've had to deal with the effects of sequestration but how has that caused a delay of 4 months?  I sold my Garmin 530W while I could still get something for it and am now renting one from a local avionics shop to use until the IFD 540 is available.  Any news on who or when the pilot program people will be selected and potentially have radios?   Thank you for your support!
JT
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2013 at 9:26am
I will report on the FAA MPSUE findings and the Code Complete milestones noted above (#1, 2) and at that point, will focus on the pilot program selection and date estimates since at that point, we have a much more deterministic schedule.
We're working weekends and holidays to get this done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkturner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2013 at 10:58am
Thank you for the information!
JT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2013 at 11:11pm
WELL It is what it is!
While others Can't wait to get a new untried unit.  I'd much rather wait a little longer  just to unsure that I will not having to send it back because of XYZ  problems.
My thoughts are, do not be pressured by us customers. When Avidyne is ready. We'll be ready.
Leonard
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2013 at 4:57pm
Did you get any FAA MPSUE findings reported yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2013 at 7:38pm
No, afraid not.    Here is an exact cut and paste from an email I got this morning from the FAA on the topic:
"We are about 75% through. We are having another meeting on Friday to finish this up, so Friday, maybe next Monday."
This is a big enough milestone that you can be sure I'll report the status/findings as soon as I get them and what our course of action will be based on those findings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2013 at 9:11am
Fingers crossed that there are no biggies.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 7:36pm
The rest of the world waits to find about about Kate's baby.  We wait to hear what the FAA said.  They (or we) should get a life...
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 8:48pm
You know what, I kind of LIKE the life I already have!  ;-)
Edited by oskrypuch - 22 Jul 2013 at 8:49pm
