  New Posts New Posts RSS Feed - IFD 440 Frequency ID Disappeared
Roger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Quote  Post ReplyReply Direct Link To This Post Topic: IFD 440 Frequency ID Disappeared
    Posted: 19 May 2022 at 2:43pm
Good afternoon everyone. The data blocks that typically house the frequency identification as well as the frequency number have disappeared on GPS #2 which is an IFD 440 that I run in tandem with an IFD 550.  Any thoughts?
It was having a difficult time picking up a GPS signal sometimes taking 10 minutes and we found the GPS 2 antenna was on an L Bracket not facing the sky.  The shop built a new mounting bracket and we seem to be good to go here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 6:42pm
Can you post a picture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 9:45pm
Yes, I will grab one tomorrow and post it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2022 at 2:44pm
Problem solved.  The user profile setting "Roger" that details my setup of the GPS had been switched over to user profile setting "5"  When I toggled the user settings back and forth the frequency displays appeared and disappeared.  I have a picture and a video that are too large to upload here.  But in any case, a simple fix.
