  New Posts New Posts RSS Feed - Webinar - New 10.3 features
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Webinar - New 10.3 features
    Posted: 01 May 2022 at 3:02pm
Don't know if you saw it, a recording of it is likely available by now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 3:08pm
Was uploading the summary screens, but looks like the image uploader is broken, I keep getting file not found.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 3:12pm
OK, here are some links ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 3:13pm
A lot of solid new features, that will delight a number of folks I'm sure.
Only disappointment for me, is that the new VNav plotting capability is ONLY available on the IFD550, NOT the IFD540, nor the IFD440.
Edited by oskrypuch - 01 May 2022 at 3:14pm
R0bst3r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R0bst3r Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 7:42pm
Thanks for posting these. Does anyone have a link for the whole webinar?
b2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b2002 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 5:10am
Can the VNAV output be displayed on other PFDs (from any IFD) or is the VNAV signal generation/display limited solely to the 550?
jhbehrens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhbehrens Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 6:21am
Thanks Steve, 10.3 looks exciting!
There was no mention of any change to the requirement that RS232 inputs and outputs connected to the same port number need to use the same baud rate, as was the case with the current version. I remember when this was introduced, it wasn't published and a few people, including me, ran into trouble. Is this change reversed in 10.3?
dfw11411 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfw11411 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 9:15am
Link to recorded webinar. Enter your info and it takes you to the video.
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 9:24am
I was disappointed when I read this, so I went to watch the webinar (which I hadn't seen yet).
In the webinar, Mike said that you'd get VNAV guidance *on the SVS page* if you have an IFD545/550. He didn't say whether or not you get VNAV guidance *on a CDI or PFD* with it. That's still not clear to me-- do we know whether this will work?
Aerochip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aerochip Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 9:31pm
Looks like a lot of nice work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 5:51pm
Being able to pipe portable sourced ADS-B data into the IFD is cool.
This requires setting the source to GDL90 format.
Normally you run a Stratus 3 NOT in GDL90 format, to work with ForeFlight. I'm wondering if setting the Stratus 3 to GDL90 format for the IFD, would result in losing sync with ForeFlight.
I have that question into Appareo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 7:15pm
.....I'm wondering if setting the Stratus 3 to GDL90 format for the IFD, would result in losing sync with ForeFlight.
And below is Appareo's answer, so you don't have control of the Stratus from FF any more, probably lose the attitude screen, but FF will work with Stratux for FIS/TIS, so should still be able to display the data.
Thank you for your email.  Yes, Stratus 3 can be run in Open ADS-B mode or Foreflight mode, but not both at the same time.
Appareo
Edited by oskrypuch - 03 May 2022 at 11:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 11:53pm
And the answer from ForeFlight, looks like it is a no-go at the moment, if you want both, but there is perhaps some hope ....
Thanks for your patience. Currently the Stratus 3 must be in "ForeFlight" mode to provide any ADS-B data to ForeFlight. If the Stratus 3 is in the "open" mode and you connect ForeFlight to its Wi-Fi network, you will be promoted in ForeFlight to change the Stratus 3 to "ForeFlight" mode.
ForeFlight can receive "capstone" data from other devices however, provided they meed our Extended GDL90 spec: https://www.foreflight.com/connect/spec/
We're discussing with Avidyne the functionality they're announced for 10.3, specifically the ability for the IFD to receive ADS-B from portable devices providing "capstone" data. We don't have anything specific to announce at this time, but feel free to check back in the future.
ForeFlight
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 10:34am
No on the analog CDI.  In order for a PFD to show enroute VNAV guidance, it needs to recognize the associated 429 labels.  The only device we have found so far that supports it is a G5.
Post Options Post Options   Thanks (0) Thanks(0)   Quote b2002 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 12:04pm
I have dual G5s and dual 540s.  Will VNAV be displayed on the G5s without a 550?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 12:12pm
It wasn't clear to me how much of the TAWS improvements would apply to an IFD540.  The illustrations in the webinar showed a 550, and there was some mention in the Q&A session that the 3-arcsecond upgrade was recommended (required?) to get the most out of those improvements.
So how would the 10.3 TAWS upgrades show up on a non-upgraded IFD540, if at all?  What would the 3-arcsecond upgrade do to improve TAWS?  Is the 3-arcsecond upgrade even an option for the 540, or is all this stuff only applicable to a 550?
Edited by MysticCobra - 04 May 2022 at 12:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 12:17pm
Yes.
Post Options Post Options   Thanks (1) Thanks(1)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 12:29pm
3AS data is just higher resolution than the current database (which is 9AS).  You'll get more detail on SVS and TAWS will have more points to look at.  But, 3AS data takes up a lot of space, so you have to send the box in to upgrade memory.  Even with that, you can't fit worldwide terrain, so it's provided in smaller regions (e.g. North America, Europe, etc.).  3AS is really good for helicopter installations because of their range and mission.  It might not make as much sense for typical GA fixed wing missions.  It is applicable to all IFDs, though, not just a 550.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 12:46pm
It strikes me as a shame that the cool new VNav feature will be unavailable to most of the IFD users out there. I'm sure it took some time and energy to develop.
Why not have a indicator bar along the right edge of the map screen (not just the 550-only SVS page), showing your position relative to path, and perhaps a +/- ft numeric at the top showing the precise offset. That is a common way to do it with many MFDs, and would allow everyone to make use of it.
Can this be considered for a future release?
Edited by oskrypuch - 04 May 2022 at 12:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 1:46pm
We thought long and hard about what to do in this regard.  That kind of data really should be on a PFD.  The egocentric SVS page makes sense, but not so much in other places.  The real shame is that other systems, like PFDs, aren't open enough to just accept the data and show it.  Rest assured that Vantage PFD will show it.  I'm sure we'll keep talking about how to improve it on the IFD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 2:02pm
Well, Boeing puts VPath indication on the ND (and PD), the little sliding bar on the right side with the magenta diamond. They have been in the trade, for a while.
The IFD is a navigation display (ND/MFD), and navigation is both lateral and vertical. This indication is an enroute one, for general navigation, and logically not the same as indications provided when on final approach on a PD. Other VPath indications like the TOD or required vertical descent rate or waypoint restrictions are shown on the IFD map, so really, why not the VPath indication.
Image from my original feature request, back in 2016. (BTW the arrows point to the fix circles -- another one of my requests)
Keep thinking on this!
We have the Banana (thanks), we may yet get the VNav path (for all), adding FIX circles would make it a trifecta! ;-)
Edited by oskrypuch - 04 May 2022 at 3:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 11:45pm
... and really, if you were concerned about the propriety of having VNav path on the map page, you could make it a user controlled option, let the user decide for themselves. There is no downside.
To me, it makes no sense to restrict it.
ricardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2022 at 1:37am
I think the way you will set up a Stratus 3i would be:
1 - Stratus 3i in open adsb mode.
2 - IFD enabling ADSB over WIFI.
Wx and traffic data will flow from the stratus to the IFD and then it will be rebroadcast from the IFD to foreflight.
So you will still be able to get Wx and Traffic on foreflight -- but it wont be coming from the stratus directly.
Edited by ricardo - 05 May 2022 at 1:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2022 at 7:26am
Thanks, Steve-- that's what I wanted to know. I don't mind not having the guidance on my analog CDI. Next year, insh'allah, I plan to put an Aspen in to replace my current CDI/HSI combo. Haven't even considered the G5 because I put it in 3rd place behind the Aspen and GI-275. Hopefully by the time I get a shop slot there will be some motion going on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2022 at 10:40am
Quote I think the way you will set up a Stratus 3i would be:
I don't believe that the 10.3 firmware will rebroadcast any ADS-B data on WiFi.
FF advises that if it sees a Stratus 3 on the network, it will insist that it be switched to encrypted mode.
But as I posted upthread, FF is aware of the new IFD capability to receive on WiFi, and is looking at it. With portable uncertified gear they can react much more quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2022 at 10:37pm
this should be simple enough to verify with 2 ipads and the IFD trainer. -- i'll try it next time i'm at my airplane (since thats where the Stratus 3i is at).
PA23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 10:02am
Probably too late to add it to the 10.3 software but to put the Stratus into open mode is to send the following HEX string via a broadcast message:
C253FF5601016E37 directed port 41500 (obviously UDP as a broadcast implies that)
Maybe this can be added to a future revision as there are a lot of Stratus 3 units out there?
-PA
AviLance View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviLance Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 11:43am
We did not want to force the Stratus 3 into open ADS-B mode from the panel mounted unit. However, if you turn on "WIFI ADS-B Support" in the IFD100 app - that will send out the broadcast message you described and switch the mode automatically.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 12:49pm
That was very wise. From what the ForeFlight folks tell me (and no doubt you are aware) that would make the FF app unhappy. If it sees a Stratus 3 on the network, it will not pull its "open" data stream, and advise that you need to change the Stratus 3 to proprietary mode!
In any case, they also noted that they are aware of the new 10.3 feature (plotting WiFi ADS-B data), but had "no announcement to make at present".
Edited by oskrypuch - 06 May 2022 at 12:52pm
Spongebob38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spongebob38 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2022 at 10:48pm
Where can I find the "Software Release Form" mentioned in the webinar?     I have searched the site but can only find the one for the Entegra EX5000 MFD [Entegra EX5000 MFD; Software Request Form - Avidyne Dealer Support]
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2022 at 10:59pm
Toadpilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toadpilot Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 6:35am
With 10.3, for an IFD 550 connected to a RDR 2000/2100 weather radar, will the 550 provide the necessary attitude information to the RDR to enable radar stabilization? I know this was discussed on previous threads as a 10.3 feature, but I did not see it mentioned in the 10.3 presentation.
Jeff Hullinger
1964 Piper PA-30 N97VP
IFD550/IFD440/EX500/AMX240/
RDR2100/GMX345/GDL69A/
SKY497/STEC60-2/G5 AI/G5 HSI
Post Options Post Options   Thanks (0) Thanks(0)   Quote b2002 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 8:05am
My understanding was that the 550 could stabilize an RDR2000/2100 prior to 10.3.
I had considered upgrading a 540 to a 550 for that reason but decided on using a GI 275 instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toadpilot Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 9:26am
From my research and discussions on this forum, the 550 with current software is not an approved source for attitude information for RDR stabilization. From prior discussions, the 550 AHRS has the capability to provide the necessary attitude information to the RDR, so it was supposed to be added as an approved source for the RDR with 10.3.
Jeff Hullinger
skitheo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2022 at 4:23pm
I believe that problem with asymmetric baud rates was addressed in 10.2.6.1 or earlier.
Edited by skitheo - 10 Jun 2022 at 4:24pm
Post Options Post Options   Thanks (2) Thanks(2)   Quote R0bst3r Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2022 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2022 at 1:21pm
Very funny!!! It feels like that. I also feel for Avidyne and the rest of the smaller avionics manufacturers who do not have dedicated DERs. I.e. Dynon, Aspen, JPI, EI, Genesys, Trio, etc. Considering it took the FAA 2 years to fix an RNAV LP approach that they screwed up at the home airport of Dutch Bros which was in Pete DeFazio's district, I'm not terribly surprised. Yeah, I know it's a different part of the FAA...
PS: the only other approach published for that airport has a MDA which is usually above the clouds.
Edited by skitheo - 11 Jun 2022 at 1:26pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 9:00am
Maybe it's time to rerun the webinar, if only to reset the timeline on page 3 ("Weeks, not months!"), given that the presentation was at the end of April ;-)
This page was generated in 0.128 seconds.
