Upcoming changes to Jeppesen JDM |
Post Reply |
Author | |
AviSteve
Admin Group Joined: 12 Feb 2018 Location: Melbourne, FL Status: Offline Points: 2236 |
Post Options
Thanks(1)
Posted: 15 Sep 2021 at 3:28pm |
If you've used Jeppesen's JDM tool, you probably know about the "count" associated with your subscription. That count gets decremented every time you download the data. If the count gets to zero and you need to download again (maybe you lost the USB stick or something), then you have to call Jeppesen to get them to reset that count. The new version of JDM is not available yet and I don't have a timeframe for you. Just thought it would be worth a heads-up for everyone to get prepared for that change.
Avidyne Engineering |
pmilanez
Newbie Joined: 28 Apr 2021 Location: Brazil Status: Offline Points: 1 |
Post Options
Thanks(0)
Hi Steve, thanks for heads up.
My currently Jeppesen subscription has an alternative tail number since the last owner had registered with the current tail number and never gave me the user and password. Based on that, I cannot change it. Is this somehow block my update process or just the endless count feature? Thanks
AviSteve
Post Options
Thanks(0)
If there's some reason that we can't get the tail numbers to match up, the subscription will continue to use the count. I don't quite understand your situation, though, so if you want to email me the details, we can work together with Jeppesen to straighten it out. slindsley at avidyne dot com
AviSteve
Post Options
Thanks(0)
**IMPORTANT**
The intent of this activity to harmonize JDM with the IFD. Do not change the tail number in the IFD. If you do that, the IFD will disable the paid options (e.g. SVS, 16W radio, etc.). If you find yourself in that situation, just change the tail number back to what it was in the first place and the paid options will once again be enabled. Most non-US registered aircraft have a dash in the tail number. However, JDM doesn't allow dashes in the associated tail number. Although there is no requirement that the IFD tail number include the dash, many of them do. So if that's your situation, don't do anything at this point. Jeppesen is evaluating the impact of changing their system to allow the dash. Sorry all of that wasn't clear in the original post. Thanks to a forum user for sending me a PM raising this potential issue.
Post Reply | |
Tweet
