  New Posts New Posts RSS Feed - NO ADS-B OUT
NO ADS-B OUT
baldcaldwell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baldcaldwell Quote  Post ReplyReply Direct Link To This Post Topic: NO ADS-B OUT
    Posted: 30 Apr 2021 at 11:17am
The equipment:
Avidyne IFD-540
SV-XPNDR-261
SV-ADSB-472
SV-HDX-1100/B
SV-GPS-250A
Well...  I tried to post pictures but this forum will not accepts files larger than 1MB....  So I'm not sure how you guys can help me without some visuals...
SV-HDX-1100B message says "NO ADS-B OUT: GPS LOST"
We need the GPS signal from the IFD-540 WAAS Navigator. We have confirmed the GPS signal for the IFD-540 is working in all other aspects.
A multimeter confirms the GPS signal from the IFD-540 is pulsing at Pin 3 on the cable into the SV-XPNDR-261.
The 2nd picture here shows NO GPS DATA in the HDX under transponder settings.
The 3rd picture here shows NO ADSB POS in the HDX under transponder settings.
1.21k Ohm Resistor at the #3 pin on SV-XPNDR-261.
At this point, we are stuck. If I switch over to SV-GPS-250A, ADS-B OUT works. But we cannot use the SV-GPS-250A for ADS-B OUT.
Any thoughts? We are at a loss...
Thanks!
Rob Caldwell
Lake Norman Airpark (14A), North Carolina
EAA Chapter 309
Model B Quick Build Kit Serial # 11B-24B / 25B
YouTube Channel: http://bearhawklife.video
1st Flight May 18, 2021
eallevato View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eallevato Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2021 at 10:07pm
What serial output format did you configure the serial port on the 440?
Gene
Gene
Post Options Post Options   Thanks (0) Thanks(0)   Quote baldcaldwell Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2021 at 10:19pm
I had the panel built for me.  I did not configure it myself.  It's a IFD-540.
However, through another forum I was advised to check the connection from pin 58 of the Avidyne 5001 connector to pin 3 to the SV-XPNDR-261.  I was not able to confirm continuity.  So I bypassed the wire with a new wire and now the ADS-B OUT function works.  But... now I am receiving a new error message on the IFD as shown in the attached picture.  Oh yeah...  can't post pictures....
Error message says "No 429 from input: #1"
Rob Caldwell
EAA Chapter 309
Post Options Post Options   Thanks (0) Thanks(0)   Quote eallevato Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 12:48am
OK, so what is connected to ARINC 429 IN 1?
Could be a LOW vs HIGH Speed selection, or the wrong protocol selected.
Did they give you a schematic for your panel?
Gen
Gene
Post Options Post Options   Thanks (0) Thanks(0)   Quote baldcaldwell Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 1:24pm
Here's the ARINC settings.
BTW...  I fixed the ADS-B OUT problem.  Replaced the wire from Pin 58 of the 5001 connector to Pin 3 on the SV-XPNDR-261 (with 1.21 K Ohm resistor).
NOW...  I am getting the following ARINC ALERT
(No I do not have a panel schematic.  Will request one)
Edited by baldcaldwell - 01 May 2021 at 1:26pm
Rob Caldwell
EAA Chapter 309
Post Options Post Options   Thanks (0) Thanks(0)   Quote eallevato Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 2:57pm
What EFIS do you have?
Gene
Gene
Post Options Post Options   Thanks (0) Thanks(0)   Quote eallevato Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 2:58pm
Never mind, you have the Dynon HDX.
Gene
Gene
Post Options Post Options   Thanks (0) Thanks(0)   Quote eallevato Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 3:15pm
Try
In1 Low Airdata
Gene
Gene
Post Options Post Options   Thanks (0) Thanks(0)   Quote baldcaldwell Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 6:03pm
Got it fixed.  Seems I bent a pin when I reinstalled the IFD.  Straightened now and working.  Thanks for your help!
Rob Caldwell
EAA Chapter 309
