Seattle Avionics & Avidyne |
Author | |||
steve.crimm@stephens
Newbie Joined: 25 Jul 2018 Location: South Carolina Status: Offline Points: 24 |
Posted: 19 Apr 2021 at 12:48pm |
Just returned from Sun N Fun and had a brief conversation with Seattle Avionics. Went to their booth to tell them they needed to start doing Nav Data for the Avidyne IFD 440 that I have. Here's what they said...take it for what it's worth... We are working on, and probably 10 months away from having nav-data available for the Avidyne products to replace Jepp and for $99.00 a year. I said great, but I'm not holding my breath. That is straight from the horses mouth, so now we wait and see. Can Avidyne comment on this possibility?
Vans RV-10
PMA7000BT IFD440 Dynon Skyview HDX |
Admin Group Joined: 12 Feb 2018 Location: Melbourne, FL Status: Offline Points: 2139 |
There are a lot of hoops we would have to go through in order to use a different nav data supplier. It's unlikely that we will do that.
LANCE
Thank you Steve! Updating the Seattle Avionics data on my Aspens takes hours. My Jepp data on my IFD550 takes seconds. My time is easily worth paying $299 for Nav Data from Jepp.
Edited by LANCE - 11 Jun 2021 at 9:09pm |
skitheo
Those are two very different sets of data. What takes you so long with the Aspen data update from Seattle Avionics is that you are updating over 20,000 NACO charts as individual PNG lossless compressed raster image files, totalling over 4 GB of data. That's writing a new FAT32 table entry on your SD card for every one of those 20,000 images. I'm sure that there was a speed/fidelity/format design trade-off years ago when avionics hardware was more limited. Another trade-off which could be made is to only install the NACO charts for the states/regions you will use, rather than the entire United States. This is what most EFB apps do for NACO charts/procedures. NavData from Seattle Avionics would be vector data and would not take a significantly different amount of time to update your IFD than it presently does with Jeppesen NavData.
Cruiser
that is an apples to oranges comparison.
data sets are not the same.
LANCE
If you'd like apples to apples, when I still had a charts database with Jepp for the Avidyne it took maybe 90 seconds. Charts for the Aspen on Seattle Avionics takes overnight. If I could get charts from Jepp for the Aspens at three times the price I would gladly pay it. The big question is why would Avidyne allocate any resources to switching data providers when it wouldn't net them one dime? They already have a reliable data provider that everyone who purchased an IFD was aware of at the time of purchase. This is a moot subject. Avidyne has worked, at no advantage to themselves, to get the pricing lowered for us. Could we possibly just let this subject rest and let Avidyne work on things that would allow them more profits for greater sales and us more features? GI275 compatibility, VNAV step down capability, etc, etc.
Edited by LANCE - 21 Apr 2021 at 10:47am |
PA23
Senior Member Joined: 12 Oct 2019 Location: MMU Status: Offline Points: 291 |
Other than supplying the data format requirements to Seattle Avionics I don't know why Avidyne would care who provides the database, unless there are some other deals going on in the background that we are not privy to.
Cruiser
It take about an hour to update the Aspen dataset from Seattle Avionics.
as mentioned above Seattle Avionics provides the georeferenced approach plate images, you are not getting those from Jeppesen charts or navdata.
dmtidler
Senior Member Joined: 12 Feb 2016 Location: USA Status: Online Points: 616 |
Not being familiar with the Aspen or Dynon units; does Seattle Avionics supply actual nav data for those units or do they only supply ChartData (i.e. georeferenced approach charts, airport diagrams, VFR sectionals, IFR low charts, & IFR high charts)?
+1 .... incl getting 10.3 out the door with RF approaches.
skitheo
What Seattle Avionics provides for the Aspen Evolution Flight Displays (EFD) is only applicable to the MFD and is a digitized (raster) version of the entire FAA Terminal Procedures Publication https://www.faa.gov/air_traffic/flight_info/aeronav/productcatalog/ifrcharts/TerminalProcedures/ NavData, obstacle, terrain and cultural database data come from Jeppesen presently as vector data which is rendered by the EFD for display. This includes the same low & high altitude enroute data displayed by the Avidyne IFDs. Hope this helps. Reference: 150hrs flying with Aspen 2000 MAX + IFD540 (>400hrs) in my airplane. EDIT: if you want to view an FAA sectional, TAC, or Lo/Hi Enroute chart, you'll have to display it on your EFB. See https://aspenavionics.com/support/database for more info about data used by the Aspen EFDs. See https://www.dynoncertified.com/charts-airport-diagrams.php for info about data used by Dynon displays. Nav Database is supplied by Dynon, possibly repackaging NACO, Seattle or Jeppesen data.
Edited by skitheo - 22 Apr 2021 at 11:37pm |
nrproces
Senior Member Joined: 19 Sep 2016 Location: Marion, MT Status: Offline Points: 138 |
Thanks(2)
I am all "IN" for this and have been, every time I write another check to Jepp...They are horrible to deal with, and SA, is a dream...
Sauce
dmtidler
tony
Mr Crimm, it sounds to me like your taking to a salesman and not an engineer. In order for a database to legally be loaded into your IFD you need a letter of authorization (LOA) and I believe the TSO for the product has to include that LOA. The certification work (cost) is substantial for both the data provider and the OEM.
Here is the FAA AC, you may want to pass this along to Seattle avionics. https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_20-153B.pdf I hate Jepp as much as anyone but Unfortunately, I'm afraid this is who we are stuck with..... |
Unknown the position of the primary person in the booth I was talking to, but both (only) individuals in the booth were in agreement. Like I said in my original post..."Take it for what it's worth" and "I'm not holding my breath". Only time will tell.
Vans RV-10
paulr
JohnAJohnson
Newbie Joined: 15 Aug 2018 Location: KJKA Status: Offline Points: 39 |
A selling point for the Dynon Skyview HDX vs a Garmin G3X is SA data at $99/year. If Avidyne were to do this, there is no doubt they would sell more boxes because of the cheaper data costs. |
MarkZ
If you fly approaches with Dynon, you’ll need an IFR navigator.
skitheo
Is that a valid comparison for navigators / FMSs? Is Dynon SV HDX using NAVDATA or charts? I.e., do they have coded instrument procedures including waypoints, holds, altitude and speed restrictions, coded into the database for flight plan retrieval? To my knowledge, Thales Group, Rockwell Collins, Lufthansa Systems, GE(?) and Jeppesen are the only certified providers of navdata. It would be great if Seattle Avionics is getting their own Type 2 LoA. I'm not holding my breath. AC 20-153B is the current FAA guidance for NavData authorization. The Dynon website implies that they may be getting some data (obstacles? Navdata?) from Jeppesen and packaging it for SV HDX.
JohnAJohnson
That's true no matter who makes the PFD. |
JohnAJohnson
The type of data used by the HDX isn't important to this discussion - it's a PFD. The topic is that SA is developing an alternate to Jepp for Avidyne IFDs, selling for $99, and if that were to happen, I believe it would give Avidyne a serious competitive advantage. I only brought up Dynon to illustrate how $99 SA data (vs. many hundreds for the Garmin G3X) is a selling point for the HDX system, as a comment on Lance's "switching data providers when it wouldn't net them one dime" statement. Edited by JohnAJohnson - 13 Jun 2021 at 5:34pm |
HenryM
To shoot an IFR approach with a Dynon HDX, you have to have a separate navigator, like an Avidyne or Garmin unit, with its own separate navdata, as others have mentioned. The SA data displayed by the HDX is not what drives an approach. You still need to pay for the Jeppesen or Garmin NavData used in the certified IFR navigator, on top of the $99 to SA.
LANCE
The price of the nav data does not drive sales for Avidyne or Garmin, it's the features of the navigator that does. If it's $99 vs. $299 in the grand scheme of owning an airplane it's pennies.
JohnAJohnson
Apples to apples, I think it would make a difference to some. But That's just an assumption. But I think your statement above may be an assumption too. As far as I know, there has never been a big difference in database cost across brands of navigators, so how would we know if it would be a discriminator? If SA is successful it will establish a new paradigm. The only navigator example I know of was the handheld Lowrance Airmap 2000C and its sales, while short lived, were cutting into Garmin's. They actively hawked that their database updates were lots cheaper than their competition's. Not quite apples to apples, since the Lowrance had a much bigger, bright color screen and a few other features that the Garmin's didn't have, but a data-point none the less. |
skitheo
For reference, when I started buying NavData for my IFD just over 5 years ago, I paid almost $500 for just the western half of the US. Now I get all of the US for just under $300. I far the prefer the Avidyne UX. We've all been hoping that Jeppesen would get some NavData competition in the GA space for a long time. If SA can pull it off, great. They'll have to also do a lot of the LoA work. I already have a SA lifetime subscription to charts for my Aspen 2000 MAX.
rpostmo
Senior Member Joined: 20 Jul 2015 Location: North Dakota Status: Offline Points: 156 |
Thanks(2)
I have to say that I've been quite pleased with Jepp now that I get my
annual NavData subscription for $299 per year for my IFD540. I don't get the charts as I much prefer looking at them on my tablet with IFLY GPS. program. Bob
