Release 10.2.6.1 |
Posted: 26 Mar 2021 at 4:18pm |
Release 10.2.6.1 is now available. Here are the release notes:
You can request the software update from this knowledge base article. |
Decibel
Newbie Joined: 15 Jan 2021 Location: CYMX Status: Offline Points: 16 |
Hi Steve, after watching the video provided with your link It says that it only can be done by authorized personnel, I just my IFD installed and they installed as is and did not install the new software version. Will I have to fly at my avionic shop for every up date like that?
Edited by Decibel - 29 Mar 2021 at 9:16am |
Regardless of who physically loads the software, the upgrade must be signed off by authorized personnel with an appropriate repair station authorization or repairman certificate. There are plenty of users who do the upgrade under the supervision of someone with said authorization who will then sign off upon completion.
So if you only have access to someone with signoff authority when you are at your avionics shop, then I would say that you need to fly to the shop for the update. |
Decibel
Thank you Steve for the reply, in that case can I skip few updates or it needs to be done regularly?
Yeah, if your system is working fine and you don't think you would benefit from any of the features of this release, then it would be fine to skip it. I would recommend upgrading when major releases come out, but since this is a minor release, use your own judgement.
If you use an NGT9000R, though, I would definitely install 10.2.6.1
Edited by AviSteve - 29 Mar 2021 at 10:11am |
Decibel
Thanks a lot
Speedbird1
Groupie Joined: 16 Mar 2020 Location: New Braunfels Status: Offline Points: 66 |
I noticed that in the Service Bulletin it mentions 'VHF manufacturing yield improvements'.
What does this mean in layman's terms? TIA!
Some low level chip configurations were changed that allowed the manufacturing process to be more efficient. It's not something you'll ever notice or care about.
cavu
Does this mean it fixes the problem? I noticed that flying an approach, it does not give me the VSR for the next fix.
Yes, the problem was fixed. VSR is inhibited, though, on ILS, LPV, and some LNAV/VNAV approaches. it's also inhibited on final regardless of the kind of approach.
teeth6
I have to go to the shop to have my 540 re-flashed due to a software glitch that developed with a chart install. Will I have to go to 10.2.6.1 after this or can I stay where I am now? Is the improvement in ADS-B reception noticeable enough that there’s a benefit to the new release. None of the other features would do much for me.
commedian
Newbie Joined: 15 Mar 2020 Location: Texas Status: Offline Points: 2 |
How do I get the following document? It's listed in the instructions for this upgrade and the A&P doing the upgrade asked me to find it.
• 600-00299-000 IFD5XX IFD4XX Installation Manual - Rev 22 or greater
If it comes back to Avidyne, it will get latest software. If the work is being done at the shop, just have them work with tech support to keep the software version you're on. The ADS-B fixes improve performance, but based on other reports in the forum, it's still not perfect.
Give tech support a call, or have your installer call. They can get it to you.
bobcain
Newbie Joined: 26 Aug 2010 Location: 7K8 Status: Offline Points: 37 |
I have a pair of IFD440’s and both presented same error when running conforming program during update from 10.2.4.1 They show error at ACR 9S12 #2 App with red checksum.
A reply from tech support acknowledged the issue and offered a resolution that provided the same results. Misery loves company, so thought maybe someone had same issue with resolution. One thing that came to mind just recently is that I never did enter a PIN. Maybe that is expected?
Red checksum isn't affected by PIN.
bobcain
dopolinsky
Newbie Joined: 11 Mar 2019 Location: ME, USA Status: Offline Points: 11 |
What is a declination waypoint?
I have an occasional dropout of the waypoint identifier on the Avidyne Entegra PFD in my Cirrus. Tech support has never been able to explain this. Is "declination waypoint" a waypoint name transmitted over ARIC to other screens on board?
I'm not aware of such a term. "Declination" is a technical term for magnetic variation. A waypoint has an associated declination simply because there is a mag var associated with the lat/lon of that waypoint. But it's not termed a "declination waypoint".
I'm not sure what any of that would have to do with the PFD not showing a waypoint identifier.
dopolinsky
I asked about "declination waypoint" because one of the bullets of the 10.2.6.1 release notes reads:
I was wondering if this has something to do with my malfunction where I periodically loose the name of the waypoint on my PFD, while it is displayed on my MFD, but not the bearing and not the distance. It is a weird hard to explain malfunction, unless there is more to a waypoint ID than just letters and I am starting to wonder if a waypoint is more than just letters and coordinates for this type of sophisticated equipment.
LOL, that'll teach me to copy/paste without proofreading. Give me a second to wipe the egg off of my face :) There was one fix that had two parts and somehow those got translated into two separate bullets in the list (that weren't even next to each other). The fixes both involved the GAMA Graphics output. First, off route waypoints (i.e. nearest airports and navaids) were sent with no mag var. The fix was to send the mag var associated with the waypoint. For airports, that's local mag var. For VORs, it's the published declination. Second, when the IFD was in OBS mode, the IFD always sent local mag var. Now, when the active leg terminates at a VOR, the IFD will send the published VOR declination. The fixes would only affect systems that receive the GAMA Graphics output and use the mag var in OBS mode. Not all systems use that mag var. These fixes wouldn't have any effect on the active waypoint identifier. The active waypoint identifier, time and distance to go are all output on separate labels.
Steve, can we get a list of updates for 10.3 in the 10.3 thread?
I'll start a new thread with the release notes once 10.3 is released.
FlyingCOham
Steve, reword the request. Can we get a succinct list of the features/fixes you've already mentioned publicly?
Jim Patton
saratogahp
Newbie Joined: 27 May 2020 Location: Florida Status: Offline Points: 5 |
Edited by saratogahp - 02 Dec 2021 at 9:57pm |
