  New Posts New Posts RSS Feed - Audio alerts
Audio alerts
Cruiser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Topic: Audio alerts
    Posted: 19 Nov 2020 at 3:45pm
I lost audio on the TOD and 500 feet alerts.
I checked the settings, all the audio in on.
the Audio page has max volume set
I use to get these before.
Can anyone help identify a cause.
Edited by Cruiser - 19 Nov 2020 at 3:45pm
PA23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2020 at 3:55pm
Any chance you have the audio alerts connected to a switchable input of your audio panel such as the ADF or DME audio?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2020 at 7:47pm
Nope, but thanks for thinking of that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2021 at 12:33pm
still not getting TOD or 500 foot call out.
Airspace, obstacle terrain alerts all work just not those two.
Any ideas ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2021 at 6:10pm
With respect to the 500 foot aural callout, have you verified that it is in fact still enabled on your IFD? I believe it is the F500 option on the IFD AUX - Status Software page.
The 500 ft callout (if the option is enabled) and TOD aurals are independently optional for each of the five IFD User Profiles via the Users Options settings. If TAWS is enabled on your IFD, it appears the 500 ft callout option cannot be turned off.  I assume you confirmed that both of those options are selected On for the User Profile(s) you normally use.
Edited by dmtidler - 06 Mar 2021 at 6:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 10:40am
"KeyValue Version"                                , UINT08, 000, 00005
"KeyValue ACM Status"                             , SINT32, 000, 000000000001
"Time Display Format"                             , SINT16, 001, 0000001
"Zulu Offset"                                     , FLPT32, 001, 0.0000000e+00..
"Comm Spacing"                                    , SINT32, 001, 000000000001
"FMS Bearing Format"                              , SINT32, 001, 000000000000
"Position Units"                                  , SINT32, 001, 000000000001
"Temperature Units"                               , SINT32, 001, 000000000000
"Fuel Units"                                      , SINT32, 001, 000000000000
"Pressure Units"                                  , SINT32, 001, 000000000000
"Altitude Vert Speed"                             , SINT32, 001, 000000000000
"Dist Speed Units"                                , SINT32, 001, 000000000000
"Nav Auto Tune"                                   , SINT08, 001, 00001
"GPS->VLOC Capture Auto"                          , SINT08, 001, 00001
"Auto Enable Missed"                              , SINT08, 001, 00001
"Switch Tank Interval"                            , SINT32, 001, 000000000000
"Selected Item"                                   , SINT32, 001, 000000000000
"Cursor Position"                                 , SINT32, 001, -00000000001
"Enable TA"                                       , SINT08, 001, 00001
"Show Terrain Exclusion Areas"                    , SINT08, 001, 00001
"Terrain Caution Aural"                           , SINT32, 001, 000000000000
"Terrain Warning Aural"                           , SINT32, 001, 000000000001
"Top Of Descent Aural"                            , SINT08, 001, 00001
"Air Space Aural"                                 , SINT08, 001, 00000
"500ft Callout Aural"                             , SINT08, 001, 00001
"Touch Screen"                                    , SINT08, 001, 00001
"Keyboard Convenience"                            , SINT08, 001, 00000
@ if Bluetooth or WiFi is set to -1, the system will have no indication that the associated feature is supported
"Bluetooth"                                       , SINT08, 001, 00001
"WiFi"                                            , SINT08, 001, 00001
"Advisory Glideslope"                             , SINT08, 001, 00001
"Chart Auto Mode"                                 , SINT32, 001, 000000000000
"Chart Day/Night Mode"                            , SINT32, 001, 000000000002
"Bezel Mode"                                      , SINT32, 001, 000000000000
"Display Mode"                                    , SINT32, 001, 000000000000
"HDI Suppression"                                 , SINT08, 001, 00001
"Heading Marks on Horizon"                        , SINT08, 001, 00001
"Map Orientation"                                 , SINT08, 001, 00001
"Hide Page Tabs"                                  , SINT32, 001, -00000000001
"Flight ID[0]"                                    , SINT08, 001, 00078
"Flight ID[1]"                                    , SINT08, 001, 00057
"Flight ID[2]"                                    , SINT08, 001, 00057
"Flight ID[3]"                                    , SINT08, 001, 00077
"Flight ID[4]"                                    , SINT08, 001, 00083
"Flight ID[5]"                                    , SINT08, 001, 00000
"Flight ID[6]"                                    , SINT08, 001, 00000
"Transponder Code[0]"                             , SINT08, 001, 00001
"Transponder Code[1]"                             , SINT08, 001, 00002
"Transponder Code[2]"                             , SINT08, 001, 00000
"Transponder Code[3]"                             , SINT08, 001, 00000
"KeyValue CRC"
