Remove Jep Charts from 540 |
M20Kid
Groupie Joined: 19 Aug 2015 Location: AZ Status: Offline Points: 79 |
Posted: 19 Oct 2020 at 10:09pm |
I have a 540 in my airplane and decided to stop paying for charts with Jeppsen; I do still get other data for the unit. Now each time I start the unit points out that my charts are out of date. Is there any way to tell the 540 that I no longer update the charts? Or to remove that portion of the database so it doesn't look for updates?
10.3 will have a way for you to disable charts through maintenance mode. Until then, you'll need a DSF to do it. I'll get that DSF and send it to you.
HenryM
AviSteve:
I'd like that DSF too. I would like to get rid of charts that aren't even for the part of the country I fly in. I also have an old obstacles database, but I suppose that database is better than nothing. I only update those once a year, and I also have them on Foreflight.
I'd like the dsf as well. I have 2 540s.
paulr
I would also like the DSF, please and thank you.
FlyingCOham
I too have an old set of charts in my 540. The problem is there are stiil many charts in that edition that are still completely current but the 540 cripples them because they came in a set that is more than 60 days old.
Example: La Junta, RNAV approaches to 08 & 26. Both were last changed in 2009 and are still valid but the 540 has no way for the user to tell it they are still current so they are crippled... ( : < ) BTW, if you have a paper copy from 2009 it is still completely legal as long as the pilot verifies it is the current chart. From 540 Pilot Guide: "Charts that have been expired for 60 or more days will still be
displayed and readable indefinitely but a watermark “Not for
Navigation” will be depicted on each chart. The flight plan will not be
overlaid on expired charts" Boo! |
Jim Patton
dmtidler
The IFD does not have the ability to verify what, if any charts from an outdated chart database are still current. From a Avidyne liability standpoint, I think the policy regarding charts that are more than four chart cycles out of date is perfectly reasonable.
Edited by dmtidler - 22 Oct 2020 at 6:54pm |
FlyingCOham
I'm not suggesting the system should be able to identify charts that are still valid - that's crazy to expect. That's the pilot's responsibility. The problem is there is no way for the pilot to exercise his/her responsibility and tell the system that this chart is still valid.
Jim Patton
Catani
Why as a pilot do you feel responsible to "tell the system that this chart is still valid?" A chart is for your reference. Your responsibility under IFR is to utilize charts you know to be valid. I see no pilot responsibility to "tell the system" anything. What am I missing? If you have confirmed the chart is current and valid, you can use it flying IFR and can ignore any flags provided by the system to inform you its chart cycle is out of date. There's no need to inform "the system" of your decision in that regard.
FlyingCOham
The problem is the 540 s/w cripples the chart if the package it came in is over 60 days old. There's no way to tell the 540 that the chart you are trying to use is still valid and should not be crippled.
From 540 Pilot Guide: "Charts that have been expired for 60 or more days will still be displayed and readable indefinitely but a watermark “Not for Navigation” will be depicted on each chart. The flight plan will not be overlaid on expired charts" |
Jim Patton
dmtidler
This brings up a couple of questions. With the Avidyne packages of digital Jeppesen chart databases, how do you determine that a procedure you're referencing is in fact the current procedure if the chart database the procedure comes from is not the current chart database? With paper Jeppesen revisions, there was a master list of current charts with each revision that could be referenced to verify each procedure's currency. Is there an equivalent online accessible Jeppesen master list of current procedures you're using to cross check the currency of each procedure you're referencing from an out of date database every 14 days? Edited by dmtidler - 22 Oct 2020 at 7:18pm |
teeth6
Good question... I am not aware of a way to cross reference to see if a chart from an older database is still current. I had assumed you should have a current database to fly an approach but you are correct that the procedure could very well be identical to an expired database. This is true of the Jepp charts on Foreflight as well. By going digital, pilots no longer have to go thru their paper charts and replace them as required.
FlyingCOham
Example: this IAP was last changed on 27Aug2009
Jim Patton
dmtidler
Are you indicating that you are using the AIS FAA Procedure Amendment Number and/or Procedure Amendment Effective Date to crosscheck the validity non-current database Jeppesen approach charts? Fun fact - the AIS published La Junta RNAV (GPS) Rwy 8 approach chart depicted above was actually last revised on 59th day of 2019 (February 28, 2019) as indicated by the 19059 above the approach title; however, whatever revisions were made to the chart did not affect anything procedural with the approach. The Jeppesen chart for this approach has not been revised since August 21, 2009.
FlyingCOham
Back to the issue. The pilot can pull out a still valid 10 year old paper IAP and use it legally but has no way to tell the 540 that the same chart is still valid - getting rid of the watermark and enabling the flight plan on the chart.
Jim Patton
dmtidler
How long after you indicate an expired database chart is valid do you propose the IFD retain that validity for that chart?
FlyingCOham
Not long, I'd be happy with a few hours or a power cycle.
Jim Patton
n7600j
Newbie Joined: 29 Apr 2021 Location: KMSN Status: Offline Points: 1 |
I would also like the DSF, thank you.
oc3068
Newbie Joined: 12 Mar 2022 Location: KTOA Status: Offline Points: 1 |
Kinda late to the party, but can I get the DSF as well?
nrproces
I would also like to receive that DSF. Thanks, in advance.
Sauce
skitheo
While we're bandwaggoning ;-) @AviSteve, Can I have the DSF as well?
Aviator52
Newbie Joined: 18 May 2021 Location: Parksley, VA Status: Offline Points: 8 |
Hello,
I have the same situation in my IFD540 as mentioned above and would like to remove reference to the expired charts on the startup page. I bought my IFD540 in November last year (2021). Can you tell me how to remove it through maintenance mode or if I need the DSF, please send with instructions. Thank you!
N828LB
Newbie Joined: 13 May 2022 Location: CA Status: Offline Points: 1 |
Can I also get the DSF?
