  New Posts New Posts RSS Feed - IFD Trainer and VLOC approaches
daveS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveS Quote  Post ReplyReply Direct Link To This Post Topic: IFD Trainer and VLOC approaches
    Posted: 21 Sep 2020 at 10:43pm
I am going to KDLS and it has an LDA approach so I thought I’d run it in the trainer.  The simulation worked fine at first with the mode starting at GPS->VLOC.  At the FAF, the mode changed to GPS instead of VLOC.  I tried several times and this remained the behavior.  I then tried the ILS at KTKI and it did the same thing.  The options are set to auto switch and auto load.
Bug in the Trainer?
dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 11:19am
I don't believe it is a bug; the IFD Trainer does not appear to simulate any navaids. In order for VLOC to engage automatically, two of the six requirements are:
  • the Morse code decoded by the tuned nav radio matches the identifier of the approach navaid
  • the radio deviations are at most 50% of full scale for 5 consecutive seconds.
Without a simulated navaid, neither of these conditions can be met to allow the automatic transition to VLOC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 11:30am
I guess that make sense but I was assuming/hoping that since this was a simulator that the app would assume the navaid was valid.  Not a big deal -- just have never actually done an LDA and don't want any surprises.
dave
