  New Posts New Posts RSS Feed - Fan B failure  on ifd 440
Rmurphy5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rmurphy5 Quote  Post ReplyReply Direct Link To This Post Topic: Fan B failure on ifd 440
    Posted: 08 Jul 2020 at 1:42pm
My unit keeps saying Fan Failure and it seems it is fan B - is there any fix for this as the unit runs fine and when I upgraded to 10.2.4.1 the fan failure was not present having been intermittent.
Rohan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rmurphy5 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 3:28pm
Bumping this - Avi Steve - is this a common issues - we have three 440s and two of them have this fault coming up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 4:52pm
I didn't quite understand this statement...
Originally posted by Rmurphy5 Rmurphy5 wrote:
... the unit runs fine and when I upgraded to 10.2.4.1 the fan failure was not present having been intermittent.
Nevertheless, the latest post says that you have two IFDs showing a fan failure?  I'm not aware of any common failures regarding fans being reported.  Sounds like a perfect job for tech support.  Have you contacted them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rmurphy5 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2020 at 1:11pm
I will download the data and send it to them Steve - thanks for coming back - yes I wondered if it was something you had come across a lot?
Rohan
piper18O View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper18O Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2020 at 11:22pm
Depending on how old your 440's are, there was a problem with the design, and there is a fix for that.  Hopefully your units are still under warranty.  I had that problem and had to send mine in.  Apparently there is a clearance issue for the fan.  That is why it fails.
This page was generated in 0.087 seconds.
